Car Nitro & Gas Engines Discuss all aspects of Nitro and Gas rc car engines here!
restarting problem
Old 12-13-2008 | 03:01 PM
Default restarting problem
i have an older car and i can start the engine easy from cold but after i have run it once it does not want to restart any ideas?
see my other post for more info on the engine
http://www.rcuniverse.com/forum/m_8230413/tm.htm
Old 12-13-2008 | 03:29 PM
Default RE: restarting problem
This is typical when the compression gets low due to worn piston/sleeve. When cold, the fit between the piston and sleeve is tighter. When the engine is new this will make it somewhat difficult to turn the engine over top dead center. At operating temperature, the ABC construction will have expanded to produce the correct fit.
So now that your engine is old and tired, the fit is decent enough when cold to provide ok compression and let the engine start. But after things warm up and expand your fit is too loose, compression is down, and it wont run as well. Try to restart it when warm it it probably wont start at all. Let things cool down and it will restart again.
Sound about right? It could be other things, but what you are saying sounds pretty familiar. You can get a new piston and sleeve and just swap that out. Depending on the engine, it might be half the cost of a new engine. Or if you were looking for some excuse to put a huge new engine in there and blow up your transmission gears, this could be your lucky break!
For what it is worth,
Spiro
Old 12-13-2008 | 04:42 PM
thats what i thought its starting to look like its just going to be better for me to get a new car this thing is turning out to be to much work.
anyone got a good suggestions for an off road buggy, nitro, around the $200 mark. used or new, something thats quick with good handling
Old 12-13-2008 | 05:33 PM
PrjctStrtFrce's Avatar
My Feedback: (10)
HPI MT2? Not exactly a buggy, but can be found relatively cheap on ebay and has a decent after-market for it.
Old 12-13-2008 | 05:41 PM
also does everything come with radios now and do they have to be digital i have a nice 2 channel am stick transmitter that i really like and would like to keep using it. i dont like the trigger style ones so i dont really want to buy a car with all that stuff if i dont have to
Old 12-13-2008 | 05:50 PM
My Feedback: (10)
You could buy it like that and then sell it and make some money off of it.
Old 12-13-2008 | 05:53 PM
not a bad idea
