Car Nitro & Gas Engines Discuss all aspects of Nitro and Gas rc car engines here!
a quick question
Old 04-23-2009 | 10:57 PM
Default a quick question
i have a quicjk question i have a os.18 cr-v engine can i put that in my traxxas revo wit it just drop in
Old 04-24-2009 | 06:21 AM
Default RE: a quick question
well, which one do you have, the roto carb or the pull carb. if you have the pull carb it can work, if you get a different clutch set up, if you have the rotary carb, you're out of luck.
Old 04-24-2009 | 06:48 AM
i have the pull start can you provide a picture of the clutch setup so i can see what you are talking bout but i do have a rb 325 motor but the lil metel piece that the nut go on to turn and crank it that lil piece is strip in that 1 spot so it just spins an wont crank
