Hangar 9 Carden Yak Electric
FL
I just started the assembly of my Yak...any other Electric Gurus out there having done this to the Yak? I am using a Neu 2215 2Y VESS 26B, Castle HV110, Spektrum 9100 and JR 8711's. Flight Power is 2 - 6S 5000 Mah in series with 2 - 2S 4000 for Radio/Servo Power. Looking for information on battery placement for CG experience. So far the build is going OK...seemed to be a LOT of poorly glued joints and the right wing a control horn was not installed! I am in the process of building a cage for the Neu motor and then will be able to better judge equipment placement for the proper CG
Jim
Jim
