Cen CT4s Hop-up
I am wondering if there any Hop-up or Upgrade for CEN CT4s? like chassis upgrade and some carbon fiber upgrade. i want to know cuz i want my ct4s to handle good in performance turns and stiffs.
CA
Here is a list of factory upgrades available for CT4S. Enjoy. PLease give us a call if you have any questions.
G84290 Threaded Alum.Shocks
CT045 Competition Drivertrain Kit
CTS01 Alum.Flywheel
CTS03 Steering Linkage
CTS04 Graphite Upper Deck
CTS05 Graphite Rear Chassis Brace
CTS06 Graphite Shock Tower
CTS07 Alum. Pivot Ball B8-M5
CTS08 Titanium Hinge Pins 46.5mm
CTS09 12 adjustable Engine Mount
CTS10 Alum. Brake Hub
CTS11 Ball Differential
CTS12 Ball Dif. Pulley T39
CTS13 Diff. Outdrive Hub
CTS14 Diff. Drive Ring
CTS15 Ball Diff. Small Parts
CTS16 Alum. Pulley T16
CTS17 Alum. Pulley T1
CTS18 Titanium Hinge Pins 58mm
CTS20 Titanium Lay Shaft
CTS21 Alum. Turnbuckle M4x25
CTS22 Titanium Main Shaft
CTS23 Front One Way Set
CTS01 Alum.Flywheel
i couldnt be bothered to read all of them so if i buy any of them which 1's will decrease top speed or improve accleration, also when is this 3 speed coming out
im far from being an expert on this car, but dont cen do a "track kit" with smaller pulleys, and/or pinions and spurs and belts? im sure i read somewhere that they do something like that. might be worth a search... just a thought mate.
other than that, what pinions are u running? u could try some smaller ones, just be careful with the gear mesh and all that... unfortunately i think the 42t green gear is the largest spur that cen make for the alloy hubbed gears that i believe the ct4 car uses. so ur left with spurs, belts and pulleys to try to get the acceleration ur after.
sorry i cant be of any more help - good luck
oh hang on - just had another thought (2 in a day - jesus...) erm, seeing as the alloy hubbed gears fit the funfactor, then wont the larger, red, plastic spurs from the 2 speed mt fit on the ct4? i dont see why not, so long as there is a cutout in the chassis so they can fit in there. if they will fit then for about a fiver or so u should be sorted. i was thinking of the 47t and 43/44t spurs, depending on ur pinions and mesh etc.
hope that bit is a bit more helpful...
You just need to change the 25T pulleys for two 16T pulleys. The part # are CT011, CT015, and CT019. Those are the 16T pulleys and the belts needed for the change. This should give you more acceleration. I ordered these parts today and will try them as soon as they arrive.
