Air Filter
What is a good aftermarket air filter for the MT2 and ATX? While cleaning out the air filter I have noticed fine dust particles inside the rubber tube the air filter is fitted into. I am currently using what came stock with it, but am wondering if there is a better filter out there. Or, is this just common. We were running around on the baseball field and did stir up a bit of dust. Does anyone have a filter you have found better than others?
Motor saver makes alot of different styles.
Did you happen to oil the air filter? They really need to be cleaned and oiled for the filter to work properly.
rolland
rolland
