genesis engine!!!
MA
Like i said before i have gotten a new genesis LE and mos of the engines i have had were not to hard to get started but for some reason i am having problems with this one. My question is how hard has it been for other people. I no i will get it up and running today or tomorrow.
This is what you can do. Heat the engine with a hairdryer on hot settings till the engine is hot as possible.Then pull the pressure fuel line from the exhaust and blow into it but look at the fuel supply line to see the fuel moving toward the fuel inlet nipple,stop blowing at that point and return the pipe back to the exhaust.Pull the airfilter of and look down the carb neck to see the throttle is open between0.5 and 1.00mm.Replace the filter.You can adjust the throttle manually with the servo.The electronics don't have to be on to start the engine!
Once you have done this apply the glow warmer and pull,it will start and at this point the engine should still be warm from the heat of the hairdryer.Always prime the engine prior to starting to make it easier and check the glowplug for distortion as it will be a sign of hydralock(flooding)
MA
well i didn't have to do it it was mainly my fault. IT was a humid day out like today but i got it started i was just to darn excited about the size ofthe truck that it made me forget some things. But thanks for the info will do on my next engine.
