C'mon CEN
#52
ORIGINAL: magoga
rolland, do you know the factory setting for the low speed screw on the carb?
high needle 3.5 - 4 turns out
idle screw set so the opening is about 1mm
Also, be sure to check that the nipple on the tuned pipe where the pressure line attaches is clear of obstructions. Seems like a bunch of the latest batch of Genesis trucks have too much thread sealant on this fitting and it goops up the inside preventing the exhaust from properly pressurizing the tank...
#53
dfn_doe is correct but here is how i would adjust them.
On the lsn I would adjust it 1/2 turn in from flush. On the hsn no more than 3 1/2 turns out 3 might be alittle better. The factory settings are incredibly rich.
rolland
rolland
