springs & shock oil
springs & shock oil
are there any different springs available for the nemesis, ( other than the stock red genesis )? or can i use other springs & shocks from a different truck? what weight shock oil is anybody using? my problem is the ass end of my truck bounces really bad when jumping, 90% of the time it lands hard on the front end. ive already busted both sets of front upper & lower arms, & hubs.
seems to me that there is too much rebound.
CA
RE: springs & shock oil
Hi rcnitronutt the best thing to do is to pull out the shock spring preloads, this will make the truck stable and controllable when jumping, it will also lower the center of gravety of truck, you will should notice a big diffrence in handling.
Note: This is our track set up.
: Shock oil # 1000
: Wheel axles level
: Toe front - 1 degree out/rear 3 deg in
: Camber frt & rear -3 deg
: Shock oil # 1000
: Wheel axles level
IL
ORIGINAL: headrush
: Shock oil # 1000
: Wheel axles level
: Shock oil # 1000
: Wheel axles level
Joe
PA
The 1000 weight oil, is that a typo? That seems very thick for shocks....... wouldn't that make the suspension very slow and not responsive?
