CEN Racing This forum is to discuss all CEN Racing products.
nemesis drill start
Old 01-27-2006 | 07:33 PM
Ing
Default nemesis drill start
What do I need to change my nemesis to a drill type starter? I see a kit with a roto-starter included for about $50, but I'd just as soon use one of my batt powered drills and save some money. Anyone have part numbers, and a good place to order from?
Old 01-27-2006 | 09:25 PM
Default RE: nemesis drill start
I think if you go with the tiger drive S680 it works better. Friend has the roto start back plate and needs a 18 volt to turn it, but it works awesome. I might go with the tiger drive myself for my LE Genesis, which is the same engine
Old 01-27-2006 | 11:16 PM
ihave the tiger drive it broke on me the first time, because for the genesis /nemesis you need to press the bearing into the housing farther so that it gets better grip on the 5.0hp motors crankshaft. I believe there is a warning on their website and/or might be a pamphlet that comes with the tiger drive now telling you to make sure and do this, Anyways the first one broke and tigerdrive replaced it free ( it took them forever to send it though) And once i did what they stated i never had a problem again. I use a 7.2 volt drill to start the truck ( its a bit slow turning over but its enough to get it started fairly quickly)
Old 01-28-2006 | 08:28 AM
nomobux's Avatar
Just buy the roto-start back plate. Mount it so that it's in the lower right. Got a piece of cold roll, drill and mount a cross pin to fit in the drive and your set. Remember to have your drill set in the right direction. Total should be less than $20
Old 01-30-2006 | 09:02 AM
scorpionx1's Avatar
dude, why spend 50 bucks on something like this unless you have $$$ to waste. the pull starter works fine as is...
my 2 cents
Old 01-30-2006 | 09:46 AM
for the tigerdrive, how are you mounting it. Are you mounting it to access from the top at an angle?
Old 02-04-2006 | 09:50 PM
Ing
Anyone have the part # for the rotostart back plate? I can't find it.
Old 02-14-2006 | 04:14 PM
yes, posted above just mounted tiger drive on my nemy. I had to trim the 2 corners. 1 by the exhaust pie and the 1 by the bottom frame plate. yes it is at an angle drill rod out by the gas tank.
roto start back plate part # G70359
Old 02-23-2006 | 07:17 PM
Ing
Thanks for the info Cmepoo. Decided to go with the tiger drive myself. Mounted it just like you said you did. Made it easy. Nice set-up. Thanks again.
