Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > CEN Racing
 Front right wheel is locked..... >
CEN Racing This forum is to discuss all CEN Racing products.
Old 02-28-2006 | 04:02 PM
Default Front right wheel is locked.....
[:@]Now after some bashing I find my right front wheel to be locked. Before I take everything apart, whats the problem? All the other wheels spin freely, but this one. I've done the diff cup mod if that helps.
Andy
Old 02-28-2006 | 07:18 PM
Default RE: Front right wheel is locked.....
I know this sounds silly but have you eyed up the drive shaft to the wheel. i bent mine like a banana and it jammed because it was fouling on the "a" arm
Old 02-28-2006 | 07:24 PM
if the wheel on the other side is turning it will either be a messed up shaft(as above ^^) or the front diff internals. Or possibly it could be a problem at the wheel hub but i dont think it's likely.
Old 02-28-2006 | 07:46 PM
Thanks but suprisingly it was the wheel nut being too tight.
Andy
Old 02-28-2006 | 07:56 PM
You've gotta watch becasue if you keep your wheel nuts are too tight you can shear off your shafts where the pin goes through on hard landings etc.
