ABS on CT5
Banned
Bounty, it really works AS I READ the statements and the owners manual. i have a new CT5, but ive yet only been able to break-in the engine. no rd/track time yet. soon though. It was Beautifull today. bwos, skies so clear you could see tomorrow.... light breeze maybe 5-10 max.... but was 32 degrees. and i dont have a plane Quite air ready YET. still have to work on the maxx's to get them ready.... when it hits 40 and decent, me and the new CT5 will be doing some laps...
it was pretty laid out strait forward on how to set up and adjust for ABS in the manual, but havent made it there yet myself.
maybe someone else can reply with more experience on this, as i ll be there in a week or 2 myself.
thanx
Tim
thanx
Tim
AB, CANADA
Your local hobby shop should be able to order you one.
OR
Try an online vendor such as:
www.customrccars.com
www.offshoreelectrics.com
Or even ebay has em
OR
Or even ebay has em
CA
lg2989 - The CT4S and CT5 are very close cars. Only some small geometry changes were made but most of the car carried over from the CT4 to the CT5.
The ABS system does work and you will have to test it out to see what setting you like the best when utilizing it.
Banned
is it the belts that you change? seems not likely as even a different length belt wouldnt make a differance in the off the line speed or top speed for that matter. isnt it a Gearing change that changes the setup, not a belt?
Timmahh
Timmahh
different pulleys and belts i believe - u cant change one without the other. different pinions and spurs are available, but the ct5s included hi acceleration belt/pulley kit has had some good feedback on here.
