Monster Fuel
My Feedback: (8)
PA
I have been using Trinity Monster Horsepower, but have been thinking about using Trinity Monster Brew. I was wondering if changing from one to another would hurt my truck. Also which one you would prefer me to use. thamks alot
AB, CANADA
If your nitro and oil percentages are the same, it will be just fine. Changing fuel and oil percentages is a bad thing as your engine will run at different temps and different compression due to more or less oil and methane.
Personally I think that any fuel is fine, other than Blue thunder.
I was using Blue thunder and I kept wrecking one way bearings, then My lhs told me that Blue thunder's dye did that to most vehicles.
Once i stopped using it, No more problems.
My Feedback: (7)
KY
IMO stay away from the Monster Brew, it will leave a real oily mess. The oil content is higher and I used this once in my MGT with nothing but regrets and a few shot one ways. I now only stick to the MHP and have had not a single problem with it.
I try and stay away from the "bashing" type fuels because the oil content is high... 18% is just too high for me. I use Byron's all the time, good stuff.
I used the MHP platinum before that was not too bad.
CA
Byron Original Racing blend fuels is the CEN Racing official fuel. We recommend using this with any of the engines that come from the CEN Racing factory in 20% content.
For more information on Byron fuels go to www.byronfuels.com
Good pick on the "official" fuel of Cen Racing
Been using it for years....... Just wish it was more widely available in my area, I gotta drive an hour to get it. When I do I buy at least 4 gallons though.
ORIGINAL: CEN Racing
CA
SPADEY - 30% Byrons will work as well, but it will wear your engine out a bit quicker because it has less oil than the 20%. If your going to go racing then you will want to use the 30% so you have more horsepower.
