nemesis or genisis?
LA
looking to purchase one of these bad boys, can anyone help me with what one i should get, whats the difference between them? any help would be great, thanks
Yes with the nemesis being slightly faster. The genny is a heavier truck but has 3spd and reverse. The nemmy is lighter but only has 2spd no reverse.
NJ
I have spent the last 2 days reading this CEN forum. and based on all the comments here, about the CEN MTs (thanks All!!)
I'm Glad,
I just got the, genesis46 LE and its A Beauty!!!! I had the Benefit of comparing the 2 side by side, and went for the LE over the nem
because,
its what I was looking for, ( A strong Big/truck.w/Reverse.) the nemesis is a bad azz Truck, but its mostly for speed at 40mph + its fast.
mine is still in the box, got it on monday I'm Reading up on it getting to know where everything is..... this weekend I'll wake it up from its factory slumber.
good luck with you'r choice.
I'm Glad,
because,
good choice on the le, the thing i did was tear the whole truck down and check all the screws for loctite and make sure the engine was square with the spur gears. the only screw that i didnt check was the screw on the plastic drive shaft and after 10 runs i lost all drive and thought i shredded all the gears. but since it has a center diff and the drive shaft allen backed out all the power was going to the front. well make a long story short i ended up taking it all apart again. i think i learned all the ins and outs of the genny so when i got the nemmi i knew what to expect. also you are going to need to adj all the servo throws so dont start her up untill you know it will throttle down when you tell it to.
and have fun, even if you crash as long as your having fun its all good, i know
