CEN Racing This forum is to discuss all CEN Racing products.
Rotostart on NT-16??
Old 05-07-2006 | 04:28 AM
Default Rotostart on NT-16??
Has anybody fitted a rotostart on an NT-16??? Im about to fit a rollcage on my ST2 but it sort of gets in the way of the pullstart (plus the one way bearing is on its way out) so Im considering fitting a rotostart but dont know if any will fit or how well they will work.
All comments/suggestions/advice accepted.
Cheers
Old 05-07-2006 | 01:13 PM
Default RE: Rotostart on NT-16??
You can fit a tigerdrive (made by sulivan products) on the NT 16 easily. You will need to buy the starter wand also. The starter wand has a ball end so you can use it at some odd angles if you need to. I have a roll cage on my FF and the tiger drive worked just fine.
Old 05-08-2006 | 04:44 AM
Thanks dustin. Ill check out the prices.
Old 05-09-2006 | 04:14 PM
S680 is the part number for the tiger start(double check i just took it off the top of my head)
EDIT:this is for the NT-16
