CEN Racing This forum is to discuss all CEN Racing products.
what is more noticable
Old 07-25-2006 | 05:50 PM
Default what is more noticable
i was thinking of upgrading my stock mt2 engine or just buying a new one.....and i was wondering what is more noticable.....the the conversion to .18 or buying a os 18 cvrx
also what is better for the price and what is required to do each
Old 07-25-2006 | 06:10 PM
poor judgement's Avatar
Default RE: what is more noticable
either will drop straight in, the cvr-x has a noticeable amount of extra power over the cen .18.
oh u may need to shorten a manifold/header bolt for the cvr-x to work, but thats it.
forgot - if the os is still around $100 bucks (a steal of a price) then get urself one, u wont regret it. how much is the cen motor?
Old 07-25-2006 | 08:17 PM
have u herd of anyone having more of a problem stripping spurs or breaking anything easier with the os
Old 07-25-2006 | 08:44 PM
also what model of the cv-rx would i need if i did get it
O.S. .18 CV-RX w/11J Rotary Carb
O.S. .18 CV-RX (S) w/11J Rotary Carb
O.S. .18 CV-RX w/11G Slide-Valve Carb
Old 07-25-2006 | 09:18 PM
alvinl's Avatar
ORIGINAL: davcenmt2
Get the CV-RX with the 11j rotary carb. It has more power than the stock motor, so you might break parts easier, but I have not heard anyone complaining about it.
Old 07-25-2006 | 09:25 PM
ok
thanks
Old 07-26-2006 | 05:02 AM
just be sure ur brakes are in good order, and u have a failsafe fitted!
make sure u threadlock all metal to metal screws, all gears mesh ok etc etc, just like u would with the stock motor - if u miss anything tho, the os is less forgiving...
if it does give u any trouble, first things to try are the metal brake seat, and run longer screws thru the engine mount plate so u can fit nylock nuts to them.
25% nitro, os#8 plug and a OS T1030 tuned pipe come highly recommended with that motor.
Have fun.
Old 07-26-2006 | 11:14 AM
what do u mean by threadlock metal to metal screws.....sorry im slow
Old 07-26-2006 | 11:57 AM
alvinl's Avatar
Threadloc is an adhesive that will keep your screws from vibrating out. You can get it at any hardware or automotive store. It comes in a tube or a stick. I like the stick because it is not as messy. It also comes in multiple colors. Get the blue stuff. Use a small dab of it on any screw that goes into metal parts. If the screw goes into a plastic part like the diff case, do not threadloc it.
Threadlock is a type of "goo" i guess, that you put on the threads of a screw before you screw it into a piece of metal. Then when the threadlock dries, it prevents the screw from backing out due to vibrations etc...
It comes in low med and high strengths. Med is good for RC, or Even low.
Old 07-26-2006 | 01:26 PM
k two more questions.....i think before i buy it........if i get the os tuned pipe can u use the stock manifold or will i need a new one....and this engine will work with two speed/well i mean the two pinion gears on my mt2 will fit on the os shaft?
thx u have been a lot of help.....i am slowly starting to learn more about my truck
Old 07-26-2006 | 01:46 PM
short answer: Yes and Yes...
Long answer: The NT 16 and OS 18 CVRX have nearly identical exhaust ports. The cen header will bolt right up (just have to cut one of hte bolt shorter), then just hook up your tuned pipe instead of the cen one.
The 2 speed clutch bell fits perfectly, as long as you get the OS .18 CVRX and NOT the CVRX (S)
Old 07-28-2006 | 07:44 PM
Parts durability with the O.S. is going to depend on where you run your truck. The weakest parts in my opinion are the dogbones/CVD's and the diff cups. These parts will probably not hold up well if you mainly run in grass. The spurs and the diffs should hold up fine.
rolland
