CEN Racing This forum is to discuss all CEN Racing products.
Matrix Racing Setups
Old 11-08-2006 | 09:58 PM
Default Matrix Racing Setups
hi
im in need of some baseline settings for my matrix buggy.
diffs?
shocks?
toe in?
camber?
ride height?
and any other ones that are needed
cheers, ned
Old 11-08-2006 | 10:39 PM
Default RE: Matrix Racing Setups
Try here:
[link=http://www.cenracing.com/race/setup.html]http://www.cenracing.com/race/setup.html[/link]
Old 11-09-2006 | 12:00 AM
i did, too specific as i dont know what the surface of the new track will be like.
Old 11-10-2006 | 02:59 AM
cant any of the team drivers hlep me out?
Old 11-10-2006 | 05:08 PM
Sorry it took so long to reply to your post .here is my setup that i use.
Diffs f5 m5 r3 i dont use the cen oil it is thicker than other diff oils.
Shocks 30 weight all around.
Shocks 2nd hole on the lower outer hole front and rear and the outside hole on the a arms.
I hope this helps you.
Dennis
Cen racing, TQ fuel.
Old 11-10-2006 | 09:16 PM
thanks alot.
will try it out today. how much difference would running 1 in the rear be compared to 3?
Old 11-12-2006 | 02:44 PM
GabeBoudreau's Avatar
ORIGINAL: nedMX
Ned try this setup. I ran it yesterday at the Best of the West shootout and had the fastest car on the track. PERIOD!
Front, NEW #2 pistons with Losi 45wt shock oil. Shocks in the stock CEN Location (upper shock mount middle, lower shock mount inside on the arm).
Rear shocks NEW #2 piston with Losi 40wt shock oil. Shocks in the upper middle and lower arm inside. Also, DONT run the rubber shock booties. I have found that they hold any dust in and change the PACK rate of your shock. The small amounts of dirt that would get in your shock are stopped by the "O"-rings.
I run the Kyosho KANI LSD diff up front with the Kyosho LSD oil. I run the CEN Matrix Aluminum diff housing middle and rear with 5,000wt Kyosho diff oil center, and Mugen 3,000 wt oil in the rear of my buggy. I run the CEN matrix stock blue springs.
I am also testing a new tank design and will give you specifics VIA email or PM. NOT on the open forum. my email is grboudreau @ gmail DOT com and my website is www.GabeBoudreau.com for more information on the CEN Racing Matrix PRO and Truggy.
I appologize for not answering your question sooner, but I was in Murreita Friday and Saturday for this race and now am off to San Diego for a test day on the Matrix TR Arena truggy.
Regards,
Gabe Boudreau - CEN Factory Driver
www.GabeBoudreau.com/trophyroom.html
Old 11-14-2006 | 08:38 AM
Here you go...I found these setup sheets on a different forum and made them PDF format!
Go ahead and download all you want! Unlimited band width to my site!
http://www.gabeboudreau.com/ARCRaceway111106.pdf
http://www.gabeboudreau.com/blanksetupsheetmatrix.pdf
Gabe
PS - Enjoy
Old 11-14-2006 | 09:57 AM
thank you very much gabe...big help
how do you find the locked front diff?
