ct4s engine mods??
well i heard that the ct4s can hook up an 21. motor with the right modifications, but is there any motors which is 12. size that could be fitted to the ct4s.
the races in sydney here only except touring cars which have a .12 motor. so has anyone hooked up an .12 motor to their ct4s and what modfication should be done to do so.
thx
thx
but dont they requie differnt clutch things and gears or do they use the same same set up with the ct4s such as the flywheel, cluth shoes and clutch
ORIGINAL: Timmahh
any .12 size motor should fit. Team Orions, Collarris, OSs ect...
Timmahh
Timmahh
Banned
yep as notch said. for sanctioned racing, you MUST USE a .12 motor. which is why you wont find a CEN NX-15 on the Team CEN Drivers cars, they are not ROAR Legal. ANY Surface .12 motor should work and mount without issue as long as its a slide carb.
Timmahh
Timmahh
