GST 7.7
i have a gst genesis and for some reson after a good thrashing i tried to use the trottle but all that happened is tat the truck crept forwrd and the revs whent crazy is this the signs that the clutch is knackered i have changed tryhe shoes to alloy ones is this the cure or do i have another problem can someone help
RI
check the set or grub srews in the driveshafts. When they come loose the engine will rev but the truck wont go any where. Also check your spur gears for wear and the gear mesh
I live in Hong Kong and really wish to buy one GST but no LHS holds this product here !! The distributor had gone leaving no support of parts. Perhaps go to shop online from overseas !
RI
you know everyone want to know how trucks are and everyone tells them their problems and usually everyone has there own. 98% of the time it because they dont know what there doing. you have to find out what YOU want and just go with it. i have 3 GST and they all work fine. i havent overheated them or broke any of them. people tell everyone that theres break but look what they are doing to them. jumping house and trying to do backflips of course its going to break but that doesnt mean its a bad truck its just not made to do that. come on its made of mostly plastic of course its going to break and if you have a bid block they like to run a little on the rich side but people lean out as far as they go and tell everyone they overheat all the time. i have never had a proble with CEN products or customer service. im not sure what you want them to do but as long as they anwer you questions and fix your problems your all set. there not going to send you a new truck!!!. pretty much go with what you can afford and what you like not what other people say because half the time they dont know what there talkin about!!
ryan
ryan
