CEN Racing This forum is to discuss all CEN Racing products.
BREAK IN QUESTION
Old 02-21-2007 | 10:46 AM
Default BREAK IN QUESTION
HELLO EVERYONE !!!!!!!!
JUST BOUGHT MY NEW GST 7.7 AND I AM IN THE MIDDLE OF TRYING TO BREAK IN THE MOTOR..........I JUST WANTED TO KNOW IF IT WAS NORMAL TO HAVE TO LEAVE GLOW PLUG IGNITOR IN PLACE WHILE THE ENGINE IS BEING BROKEN IN?????
EVERTIME I REMOVE THE IGNITOR IT FLAMES OUT....I REPLACED THE GLOW PLUG TWICE AND ITS STILL DOING THE SAME THING???
IF ANY IDEAS I WOULD APPRECIATE IT
THANKS JOHN
Old 02-21-2007 | 12:27 PM
Banned
Default RE: BREAK IN QUESTION
yes its normal but you should not have to leave it on more than a min. 1 cause it will blow your igniter 2.you engine not running right[8D]
check your idel scew mabey your idel is to low
how many tanks have you had through it?
Old 02-21-2007 | 02:27 PM
thanks for the response ...............i have the gst factory break in settings set as they came but once i pull the ignitor it shuts off....any ideas?????
Old 02-21-2007 | 02:29 PM
i have a half of tank through it ,but it was with ignitor left on while running
Old 02-21-2007 | 03:59 PM
low needle is too rich. Do you also have raw fuel coming out of the exhaust ?? or puddles of oil/fuel residue ? Try leaning the low needle and see if that'll fix it. Don't lean it too much tho till you have broken in the engine, just enough to keep it running w/o glow driver...
Old 02-21-2007 | 04:52 PM
The Real Dogman's Avatar
Neriyah Is Absolutely right!!! Lean out just enough to keep running without glow igniter and remember to turn in 1/8 of a turn Increments.
In Fact the N-tune Dial would be great for this job. It can be found [link=http://rchardware.com/]Here.[/link]
Old 02-22-2007 | 07:06 AM
thanks alot guys i will try it tonight!!!!!!!!!!
Old 02-22-2007 | 10:04 AM
hey guys ,
well i have tried leaning out the low speed needle ......switched out the glow plugs,now the truck will not start...this is my first nitro truck so im sure that it is something simple...i had run one full tank thru it ...pinched fuel line .......let it cool down ,filled with fuel......... wont start so any suggestions you guys would have would be great!!
thanks in advance
john
Old 02-22-2007 | 11:16 AM
well first off would be carefull with gettin advice from Headrush???
can barley tune his own stuff let alone help anyone else???
trust me i see him at the tracks all the time?? 15 been running like 6 months? and can barley get around the track???
theres a few motor fourms here in RCU they have some very good advice there as well....
but sticking to the Instructions is the best advice......
and you can run it with the ignitor...may burn the plug..but during break in this is not uncommon.
with the amount of people on the planet there are way to brake in a motor???
so i stopped giveing advice on this subject........
Old 02-22-2007 | 12:58 PM
Banned
well im 16 running for 6 years and all my motor are tuned right nad thats the least of my worries when i go race
cause i dont run stock motors like blade
and i can run faster then blade if he can ever get his car started hahaaha
