CEN CUSTERMER SERVICE
taj,
Can you post pictures of what you do have. I know you said what you have but pictures speak a thousand words and I think that would be best at this point. then we would be very clear on what is missing....
Taj,
Are you talking about the red anodized braces? If you have the red anodized braces, then unfortunately they are not a direct bolt on to the truggy. You can still attach them to the chassis though.
Here are two ways I have done it.
1) First dremel off the raised edge on the bottom of the brace next to the where the screw threads in from the bottom of the chassis.
2) Notch the chassis for the raised edge and drill a hole through the chassis for the screw and one for the raised edge. This is the harder method, but it feels more solid to me.
Otherwise, if it is another brace, I might need to see a pic to be able to help you out.
AK
yeah thats what i have, the red anodized braces. i think i will do the latter one. i was looking at the stock brace, i will cut off the center diff part to complete the gap in the brake housing. it should be good, unless there is other way.
NC
My new NEMESIS showed up today.This thing is MASSIVE
Im so excited I dont know what to do.Its a dream come true.I will get with you guys later
#31
NC
Break-in has been flawless so far.Idled out 3 tanks today,about a little more 1/4 a tank at a time,then putting piston BDC and allowing to completly cool inbetween.Tomorrow I will slow roll/heat cycle two more tanks and I will talk to ya then
#33
CA
We do our very best here at CEN... Erik "notch" Johnson has been doing a fine job overhauling the repair and cs phone protocal at our company....
thanks notch
thanks notch
#34
NC
You do your best.
I can testify to that.Im in NEMESIS heaven.If theres such thing as the perfect rc,this is it.Not one single problem so far
Break-in and everything after has been absolutely FLAWLESS
My NEMESIS IS PERFECT.The only upgrades are a MGT primer bulb,TRAXXAS 5 cell hump pack and in-line filter.ABSOLUTELY FLAWLESS.BRING IT ON SAVAGE
