CEN Racing This forum is to discuss all CEN Racing products.
stripped Head
Old 07-18-2007 | 07:53 AM
Default stripped Head
Hi there, I may be the unluckiest guy in this forum. My engine head stripped where you put the glow plug. I cannot screw anymore glow plug. My engine is almost brand new and it got only about 1/2 gallon in it.
Is there anything i can do ? IS there any warranty for that. I bought a matrix buggy RTR from amainhobbies in june.
Old 07-18-2007 | 08:23 AM
nomobux's Avatar
Default RE: stripped Head
ORIGINAL: mordraid
You'd be very lucky to warranty that. New head button would be the best solution. Cheap and easy fix.
Old 07-18-2007 | 08:50 AM
I would buy a new engine before a repair that so-so RTR engine
Old 07-18-2007 | 09:06 AM
nomobux's Avatar
ORIGINAL: mordraid
To each, his own. Just trying to help. Is it the GO engine ?
Old 07-18-2007 | 09:33 AM
The Real Dogman's Avatar
ORIGINAL: mordraid
I will pay shipping if you do EDIT: (DONT) want to repair that "So-So" Engine........
Seriously!!!! PM me..
Old 07-18-2007 | 10:07 AM
burningpoo's Avatar
Dogman...you're really about helping everyone have a great time with there over priced toys. That's hard to find anywhere. So for one...thank you for trying to help everyone. and two...you really might be off your rocker dude, but thank you
Old 07-18-2007 | 10:09 AM
ORIGINAL: nomobux
ORIGINAL: mordraid
It is the NX-26 engine
Old 07-18-2007 | 10:17 AM
nomobux's Avatar
ORIGINAL: mordraid
ORIGINAL: nomobux
ORIGINAL: mordraid
Ok .. you have the matrix c-1, not the TR Arena.
Old 07-18-2007 | 10:55 AM
ORIGINAL: burningpoo
OOps ReRead That Post I mistyped(That'll Get You In Trouble)
Old 07-18-2007 | 10:58 AM
nomobux's Avatar
ORIGINAL: The Real Dogman
I thot you were SUPPOSED to be working !!!! Jeeze .... Just made the 200 club. Wadda I win ?
Old 07-18-2007 | 11:00 AM
NOMO, KMA Buddy. I can't work I am too distracted!!! Matrix Arena Is Arriving Today!!!! WooHooo!!! I Win!!!!!
ADDED: You Win A Kick!! Choose A Spot!!!
Old 07-18-2007 | 06:12 PM
dStruct714's Avatar
TRD,
Nice so you finally found one eh? Let me know how it goes..
Hey back to the topic at hand, sounds like just a stripped button, you can pop the stripped one off the head and just replace it, did it strip while the motor was running, or have you moved the piston since it stripped?
There could be small bits of metal in the cylinder so you're going to want to clean those out when you have the head off, anyone have any tips on that?
Good luck!
Old 07-21-2007 | 09:27 AM
sounds like a repeat problem . i once had the same thing happen to my nemesis and it was still new from the box i only unscrewed the glow plug out 5 times before it stuffed up the thread ... seems like the same old problem continues over to the gst 7.7
Old 07-22-2007 | 03:55 PM
dStruct714's Avatar
From what I've heard the button in the head is made of Aluminum and it's a softer metal then the steel glow plug, so it's easy for it to be stripped out. Even while unscrewing the glow plug I always take my time and make sure I do it straight, and a little squirt of WD-40 before removing the plug helps clean the dirt away and keep the threads clean (thanks for the tip TRD) so when you go to re-install the plug it's easier to feel the threads and not cross-thread it.
Old 07-24-2007 | 11:36 AM
If it's the NX26, then I am afraid that the head button can't be replaced as the heatsink is still a one piece unit on that engine.
The TR28, TR28 (SH Version), NX76, GST 7.7 engines all have a removeable head button. But the NX26, NX15, and NX18 (16 as well) these engines do not.
Old 07-24-2007 | 11:40 AM
ORIGINAL: s5lin
Yeah that is exactly what i've found. I tried to remove the head button but unfortunatly, it can't be removed.
