CEN Racing This forum is to discuss all CEN Racing products.
Stripped Gear Tooth
Old 09-13-2007 | 08:26 PM
Default Stripped Gear Tooth
One of the teeth on my CEN Matrix Buggy RTR Spur Gear stripped and the clutch bell is worn in as well. Does the replacement have to be CEN parts. Total noobie question. Sorry. Both my LHS do not carry CEN parts so it would be easier if I could pick the parts up instead of mail order.
THanks. Rob
Old 09-13-2007 | 10:24 PM
burningpoo's Avatar
Default RE: Stripped Gear Tooth
to be safe I would get a cen part...but I love to play around and would try to mock up something to see how they spec up...then I would do something dumb and try to make it work...it's all about how much you want to pay/if you care/howmuch you pay...I go by gut...might not help but you learn
Old 09-14-2007 | 01:07 AM
hey r47 smiley i run a matrix pro kit on the track an im not using cen difs nor a cen center dif or spur gear im running kyosho all around they are an exact fit just find a kyoso center dif for a 777 or 7.5b and it will bolt right in no mods !!!!!
Old 09-14-2007 | 09:28 AM
thanks for the response. My LHS sells Kyosho so I should be able to get parts from them.
Rob
