CEN Racing This forum is to discuss all CEN Racing products.
genesis le tranny
Old 09-29-2007 | 12:53 PM
full maxx's Avatar
Default genesis le tranny
when trying to accelerate it seams to be slipping in and out of gear or it just revs up and dont move then when it goes back to idle you can hear it engauge the tranny... whats up thanks in advance
Old 09-29-2007 | 01:06 PM
jombo's Avatar
Default RE: genesis le tranny
it sounds like you lost a pin in the drive shaft the front one the plastic shaft has a pin or the rear .most likely the front plastic, pin came loose or you lost the pin all together. whats happening is all the power is going to the center diff and since the drive shaft is loose its just sending all the power to the front and none to the rear. i highly dought its a tranny issue unless you locked the center diff.
Old 09-29-2007 | 01:27 PM
full maxx's Avatar
no i just rebuilt the front shaft cause the pins were wearing into the plastic so the front just got a new shaft and it sounds like a hard click when it engauges and the center diff has never been locked could it poss. be the owb behind the spur gears
Old 09-29-2007 | 01:30 PM
The Real Dogman's Avatar
Check the one-way outside the tranny, sounds like it is failing!!!
Old 09-29-2007 | 01:38 PM
full maxx's Avatar
ORIGINAL: The Real Dogman
where is that located and by the way real dog man i am sorry for my attitude in the past thread ...genesis to gst
Old 09-29-2007 | 01:42 PM
ORIGINAL: full maxx
No Problem already forgotten, The oneway is located iside the second gear spur gear.. If you need a pic I will see if I can dig one up for ya
Old 09-29-2007 | 02:02 PM
full maxx's Avatar
cool thanks and is this something i can get separate do i buy the spur set
Old 09-29-2007 | 03:00 PM
Sure you can order the one way separate and replace it by following [link=http://www.cenracing.com/downloads/TRonewaywriteup.doc]My Instructions Found on CEN's website download section..[/link]
The one way can be ordered from eBay or the manufacturer and they are very inexspensive..
Old 09-29-2007 | 03:55 PM
full maxx's Avatar
hey thanks alot d.m. just wondering if [link=http://cgi.ebay.com/NEW-CEN-GST-GENESIS-SPUR-GEAR-ASSEMBLY-ONE-WAY-1-WAY_W0QQitemZ180163162778QQihZ008QQcategoryZ44028Q QssPageNameZWDVWQQrdZ1QQcmdZViewItem]this[/link] will work cause the cheapest i can find otherwise is $33. keep in mind tat mine is an le
Old 09-29-2007 | 04:28 PM
Yep that'll do it!!
Old 09-29-2007 | 04:51 PM
full maxx's Avatar
cool thanks loads.... thinking about the way it works it only makes sense and since i took it apart i know for sure cause it does slip sometimes spinning it by hand and it really sucks cause i haven't even tuned it good yet
Old 09-29-2007 | 09:19 PM
jombo's Avatar
i totally forgot about the one way bearing there, i keep forgetting the 2 speed is on the outside of the tranny
Old 09-30-2007 | 12:48 PM
full maxx's Avatar
well i hope its ok to do this but i cleaned the one way with a little fuel and three tanks later it has not missed a beat how ever i am still fine tuning ...running a little rich since the engine is only 4-5 tanks past break in
Old 09-30-2007 | 12:52 PM
Yeah its ok Maxx. My expeirience has been that once the oneways start to fail they will even after cleaning, so be sure you get one ordered so when it does
