CEN Racing This forum is to discuss all CEN Racing products.
Genesis 7.7 problem Help!
Old 03-30-2008 | 05:23 PM
Default Genesis 7.7 problem Help!
I just have broke in, and it runs great. But I have noticed the front end is pulling the truck, and hardly any power is beng sent to the rear axle. So i figured it needed heavier diff oil or put the center diff lock in. Well the allen head bolts are so tight that I snapped my good allen wrench off in it. So I went to the other side and thet are so tight that they will not come loose. Any suggestions well be appreciated
Old 03-30-2008 | 07:48 PM
burningpoo's Avatar
Default RE: Genesis 7.7 problem Help!
I read somewhere that someone stuck the diff in a toaster oven at 200 for a few min to break down the thread lock. I haven't tryed it yet but was going to when I get some 500k oil for the center diff. I was going to lock the center but I like gunning it from the start and don't really care about wheelies.
Old 03-30-2008 | 08:13 PM
The Real Dogman's Avatar
Yes Poo is very right, CEN likes to use red loctite in the diffs(keep things from coming apart under accel). All you have to do is heat the diff to 200*f to "melt" the locktite.
Old 03-30-2008 | 09:34 PM
Thanks, I will have to give it a try. Any suggestions on removing the broken allen wrench from the bolt head?
Old 03-30-2008 | 09:57 PM
You could try drilling it out with a high carbon drill bit, or try tapping the diff on a hard surface to "Knock" it out but highly doubt that will work
Old 04-03-2008 | 08:25 PM
I heated up the diff and the bolts popped loose much easier, Thanks for the tip
Old 04-03-2008 | 09:52 PM
Great Glad it Helped!!
Old 04-04-2008 | 03:44 AM
i use a pocket butane torch for the diff screws,also good for the field box,
for the broken allen you could dremel a slot in the screw.
