CEN Racing This forum is to discuss all CEN Racing products.
Genesis Diff Oil
Old 03-30-2008 | 10:16 PM
Default Genesis Diff Oil
What wieght of oil does anybody recommend for the front end diff? It is pulling with the front too much and do not want to put the center diff lock in.
Old 03-31-2008 | 11:22 AM
burningpoo's Avatar
Default RE: Genesis Diff Oil
Changing the front oil wont change that. I would start in the center with 300k-500k oil and if you still want to do the front and rear it depends on you. I'm going to try 80 in the front, 500 in the center and 90 in the rear. I'm almost certain that's the #'s I've seen from a few bashers out there. I might put something heavier in the rear but I'm unsure as of yet. Any way...start in the center so the rear wheels get more power and go from there. Don't forget to heat the screws so you don't stripe them out.
Old 03-31-2008 | 06:53 PM
Thanks once again burningpoo, I will give that a try.
Old 03-31-2008 | 07:37 PM
burningpoo's Avatar
No problem. With way to much reading you'll find other post about the diff oils. Are you trying to race, bash or both?
Old 04-02-2008 | 02:01 PM
all purpose racing and bashing.
Front: 7,000
Center: 100,000
Rear: 7,000
Old 04-02-2008 | 06:30 PM
CEN Racing's Avatar
Yes- thicken up the center if you don't want so much front wheel spin
Old 04-02-2008 | 10:17 PM
I went with 50,000 in the center diff, 10,000 in the rear and 5,000 in the front. I will post once I give it a try, I am waiting on new A-Arms broke one the other day so have had plenty of time to prepare. Thanks again for all info.
Old 04-03-2008 | 02:00 PM
i have the center diff locked but the truck seems to rock around on my wheelie bar would diff oil in the rear fix this or not? i was thinking like 7000wt thanks
Old 04-03-2008 | 08:23 PM
The combination of 50,000 in center diff and 5,000 in front diff and 10,000 in rear diff worked great for what I was looking for. I am more into to bashing around so forth. It likes to pull wheelies quite easliy.
