CEN Racing This forum is to discuss all CEN Racing products.
diff baking and other ?
Old 04-20-2008 | 06:20 PM
burningpoo's Avatar
Default diff baking and other ?
I'm about to clean my GST diff so I can toasteroven it, and was wondering what kind of cleaning everyone did before sticking it in at 200. WD-40 would probably light up, unless it sits for a few days and I don't want to use soap because of the barings. Also when I rebuild should I use assembly grease or the diff fluid for the outer gears? Why is there a hole in the cup for the center shaft diff? Thought that was a closed system. Does the nemesis center shaft diff cup have a hole in it also?
How many people have steep hill climbed with there GST? The runway isn't the greatest, haven't tryed but the truck takes off fast. I was thinking 300k center, 60 rear and 50 front but might go 120k to try and keep the nose down if I get trigger happy.
Thanks.
edit
I don't have any degreaser that I can find, and I'm feeling lazy and not going out untill tomorrow.
Old 04-21-2008 | 06:20 PM
burningpoo's Avatar
Default RE: diff baking and other ?
I finaly found the page I had on my old computer, mineral oil was what I wanted to try cleaning the diff's with.
Old 04-25-2008 | 09:23 PM
My fav cleaning solution for metals is "Brake Kleen" or any other brake parts cleaner.
If you want to strictly hill climb, I would definately stiffen up the fron diff, but if you plan to go racing, you'll probabaly end up with some serious understeer.
Old 04-26-2008 | 10:31 AM
burningpoo's Avatar
I never run with anyone so I'm trying to setup for jumping, mudding, hill climbing and flat open areas. The smaller places I go there isn't room to open the truck up, it's more like a dirt crawling place. But I can still get air with a short runway, haven't tryed that spot with the cage on yet.
Old 04-27-2008 | 08:00 PM
burningpoo's Avatar
Baked my diff for 45 min at 250 and could only get the screws out of one side. Think I'm going to use fire[>:] for the next one. Should of did the diff oil when I first got the truck, cheap stuff in there and cheaply put in. Teeth are starting to get eatin. And a fat cat that rolled in chalk, water didn't take it off
ID:	938544   Click image for larger version
Old 04-27-2008 | 11:20 PM
PENGUINBLASTER!!!'s Avatar
How do cat's clean the top of their heads anyway?
Use a butane torch or soldering iron on those screws, that's what I do.
Old 04-28-2008 | 11:10 AM
burningpoo's Avatar
Fat boy get's his head licked by his brother, other than that it's funny watching him try and clean himself.
I wonder if the 0-800 in 1 second soldering iron will work. I think it just arks to get the heat so if I try I'm going to use my temp gun to see how hot it gets. But most likely I'll use my flexable turbo jet lighter or the torch for a bigger blast of fire[sm=lol.gif].
Old 04-28-2008 | 11:19 AM
nomobux's Avatar
ORIGINAL: burningpoo
Soldering iron with a pencil tip on the screw head works well . the ones on my Matrix TR bellcrank were almost like they were welded in and it got them out.
Old 04-28-2008 | 08:02 PM
buringpoo did you get you part yet?
Old 04-28-2008 | 08:53 PM
The Real Dogman's Avatar
ROTFLMAO!!!!! Did you see those Homer Simpsons PJ's???? LOLOLOLOL he's so smart!!! loollololololol
Thanx Poo I needed that!!!
Old 04-29-2008 | 10:06 AM
burningpoo's Avatar
ORIGINAL: forevernitro75
Yup, you rock man. That thing was brand new looking, I can't thank you enough.
Old 04-29-2008 | 10:08 AM
burningpoo's Avatar
ORIGINAL: The Real Dogman
That's my bro, he lives in pj's LMAO
Old 04-29-2008 | 03:38 PM
bp it was brand new just didnt need it
Old 04-29-2008 | 04:10 PM
burningpoo's Avatar
Let me know if I can do anything for you then, I'll do what I can.
Can't wait untill my back stops hurting so I can open up the other 2 diffs.
