Center skidplate...
Hi Mr Terminator, I'm not sure, but i made one for mine, it has been excellent so far, skidded over the top of a pile of sharp rocks a month or so back, (when my GST was running) and if it wasn't for my home made skid plate, it may have damaged something, cause the skid plate ended up with some big scratches in it. Sorry I couldn't be more helpful
HG do/can you get some pictures to show? I'm thinking of making something up since I messed up the plastic front shaft when I high sided on a dirt pile.
ORIGINAL: burningpoo
Cheers Nomobux,thats great dude and special thanks to Harley Gal for a job well done.I've got some 3mm alloy plate so will get it cut and shaped.Thanx guys....[)]
Glad you like it guys, and thanks Nomobux for putting the pic up, I actually tried to post it when I did my reply, but it didn't work, I have never put a photo in here, so I'm not sure how too, lol [&:] so thanks Nomobux
OK guys .. you can now see that HG has things to contribute ............ Time to help her .. See her ongoing dillema ( sp ) and post your thoghts. thanks guys
When you're finished typing in your reply window,at the bottom of the window it says click here to upload images and files,click it and another window opens with multiple browse buttons,just press one and add any file or pic from your PC and then press upload,when its uploaded the promt will let you know.Job done...[)]
Here's what I got to bend for my center skidplate, 6"x24" 16 gauge sheet metal. Now the fun part is that I only have a dremal to cut it
, that's going to take some work. It's going to take some time but when I'm done I'll post some pictures. Now it's time to find something to use to bend it. When it stops raining I'm going to see if there are any poles around here with the right curve to it
. Unless the 12 or 14 gauge metal my friend has will work for a wheelie bar, I might use the scraps from that for the wheelie bar and just make a suport brace to stop the flex.
HarleyGal how did you bend the metal for your center skid plate? Are those the only 2 mounting points? Is your mount flush or is the edge ground off? I'm thinking of making 2 mounts for the center, but I'm unsure if I'll get that done. My other thought just walked away with the dog...
