ERROR ON CEN SITE
i was looking at the needle settings and found here http://www.cenracing.com/cars/nemesi...structions.doc
It says LSN 1.5 turns in from flush... This mistake already made me think i had a bad engine and bought a new one and i dont think it should happen to someone eles. This is the 2nd time i found this on your site. So could you please fix it so you dont make MORE of your customers mad...
I pointed out the same issue with the GST document, to CEN, a few months ago.
My engine seems to run best with the LSN closer to flush. Does anyone out there think that this is too lean?
Hi
It can be a bit confusing because on CEN web sit it says :"Bottom end: Flush – 1 turn OUT from flush"
So is it in 1.5 turns or out 1 turn ???
Here is the link :
http://www.cenracing.com/downloads/E...Doc%20NX76.doc
Here is the link :
Apperently no one at cens checks this kind of stuff... I was told it was 1.5 out from flush and i know if you run 1.5 in from flush the engine will overheat and drive you crazy and make you think you have a bad engine... Its very nice cen just igrones this post. There needle settings errors and not following through with sending me the parts that did not come with my reverse kit just pisses me off more then you can belive. Espcially since i have found the wrong needle settings on there site twice now and then you have also found it too...
My Feedback: (7)
NJ
so what are the default needle settings im looking for them also i have some over heating issues, and just as i took my glow plug out for the first time the head button striped and i cant find the part number. [
ORIGINAL: arcboyz
There is a few on ebay.
http://search.ebay.com/search/search...ead&category0=
