CEN Racing This forum is to discuss all CEN Racing products.
question on gst gear mesh
Old 05-08-2008 | 07:52 PM
Default question on gst gear mesh
i have a question on my gst gear mesh if this is ok/normal/bad. i just put my engine back in from haveing it out of the truck (other reasons that i have posted on here) but any way i just put it back it and now i am trying to get the gear mesh correct. there is a little sound comming from where the engine gears meet the transmission gears. the gears are not tight or grinding they spin pretty smooth. my question is that sound ok? its not a griding sound its more like a ringing sound. also when i put the engine back in i used lock tight (blue) while i was setting the engine that is ok it still will dry even though i was screwing and unscrewing the screws to set the engine.also the part numbers on the four gears are gs087,088,089,090 correct?
Old 05-09-2008 | 12:04 PM
burningpoo's Avatar
Default RE: question on gst gear mesh
It sounds like the metal is just ringing, I've heard that from my truck before. The last time I set my mesh I had to unscrew it 3 times, it didn't take long though, and it held up great when I crashed
Old 05-09-2008 | 03:13 PM
ok cool so everthing is ok the lock tight should have been ok to dry cool i will try tomorrow and see how she runs i also installed the ofna primer on the gst also from the muffler to the gas tank
