cen gen roto problem
hello
recently got a genesis 2nd hand and it seems as if the roto start will not turn the engine over, when i remove the glow plug it works fine and tunr the engine over, but when i put it back in, it struggles to turn the engine offer. I had a look at the one way bearing and cant see that anything is making it slip, The rotostart is fully charged so there must be enough power to turn it over.
anybody with a clue please reply.
Thanks in advance
Thanks in advance
ok well it seems as if i can get it to turn over, loosing the plug helps a bit, but still no start, i did notice the plug does NOT get wet. also i see the fuel keep returning back to the tank? is it maybe a compression problem? i have a fully charged glow heater,plug, roto battrey.
any help would be good
