Deception 40 Scratch Build
Old 01-02-2011 | 12:54 PM
  #51
Default RE: Deception 40 Scratch Build
David,
The basic box is finished and ready for the razor plane. I'm not doing any building today as I have the stomach flu.
I emailed Scott with a request for the cores.
I'll post a pic later.
Mitch
Old 01-06-2011 | 07:02 PM
  #52
PatternPilot's Avatar
My Feedback: (58)
Info sent on cores... anyone else needing cores ? contact me for info
scott
Old 01-06-2011 | 07:48 PM
  #53
doxilia's Avatar
Hi Scott,
did you send me an email? As mentioned, I'm interested in a set.
David.
Old 01-06-2011 | 08:44 PM
  #54
My Feedback: (58)
David,
sent you private email.. got your info on the other project also...
scott
Old 01-09-2011 | 08:34 AM
  #55
Here is the box, ready to start shaving with the razor plane. All wood grain that must be carved runs fore and aft. The only glue used on the pieces to be carved is weldbond (white glue). These two rules make the job go much easier.
I love this part, I feel like a sculptor.
It's easy, just remove everything that does not look like a Deception.
Well here we go with sever issues again!!! I'll post the photobucket link:
Old 01-09-2011 | 01:09 PM
  #56
Progress made while watching the Chiefs get beat:
Old 01-09-2011 | 07:38 PM
  #57
Roguedog's Avatar
Mitch Niiicce!
Always love to see a rough work formed into a thing of beauty. Excellant job.
Bryan
Old 01-10-2011 | 02:54 PM
  #58
Thanks Bryan!
At this point I can move to shaping and installing the vertical stabilizer. I can't make much more progress on the fuselage without the wing.
Mitch
Old 01-10-2011 | 05:49 PM
  #59
My Feedback: (58)
Mitch,
Foam is on order it will be blown and cured in a few days... Then the fun starts....
scott
Old 01-11-2011 | 05:30 PM
  #60
My Feedback: (58)
Mitch,
contact me at [email protected] have a question for you..
Scott
Old 01-11-2011 | 05:33 PM
  #61
My Feedback: (58)
anyone else want cores for the plane ?
scott
Old 01-11-2011 | 11:32 PM
  #62
doxilia's Avatar
For the public record, yes, I'm taking a set - but Scott already knows that.
May there be more Deceptions of all sizes!
BTW, Scott has hinted at the possibility of making glass canopies for the D40. If so, that should make the model more apppealing to those who might be considering a piped RE 45 under the hood - late Kimbro style!
Ed (NM2K), come on, you ought to jump on this opportunity! I seem to recall you mentioning that you very much enjoyed flying 40 size models at some point in the past. I understand that you also played a role in the airfoil design of the Deception - care to tell us more about that? I'd be most interested - very funky yet cool airfoil. Max thickness is way back! I'd have to draw a line down the wing planform to see if max thickness varies in distance from the LE - Side Pocket style. Haven't looked into that.
David.
Old 01-12-2011 | 04:39 PM
  #63
Here is the balsa canopy ready to become a "plug". I'll ship this to Scott (PatternPilot) tomorrow to be made into a mold for fiberglass canopies.
Old 01-12-2011 | 07:15 PM
  #64
doxilia's Avatar
That's what I wanted to hear - way to go Mitch and Scott!
David.
Old 01-13-2011 | 09:35 AM
  #65
My Feedback: (58)
Who needs canopies...pricing soon
Old 01-13-2011 | 10:04 AM
  #66
alcarafa's Avatar
Isnt lighter, simpler, cheaper and faster to make them vacuum formed ?
Old 01-13-2011 | 10:07 AM
  #67
doxilia's Avatar
Rafa,
perhaps but then there would be no option of pipe under the hood. Also, this is an all painted canopy so transparency is not of much interest (well, maybe it's just me).
Just sent you a PM.
David.
Old 01-13-2011 | 01:08 PM
  #68
My Feedback: (58)
They will be light....
Old 01-19-2011 | 06:53 AM
  #69
My Feedback: (58)
Got the plug looks good, just a few touch up items. Wing work also being done.
Scott
Old 01-19-2011 | 09:27 AM
  #70
doxilia's Avatar
Excellent! Looking forward.
David.
Old 01-19-2011 | 03:09 PM
  #71
Great! Looking forward to your good work. Yes, I would have sealed it, coated it with glass and polycryllic, then used filler primer until it was smooth and then sprayed it with lustercoat. I also would have hollowed it out.
I like having a source for fiberglass canopies much better!
Can't wait to get my hands on those wing cores so I can get back to the build!
Old 01-21-2011 | 08:07 PM
  #72
My Feedback: (58)
build thread on canopy plug and mold on the other classic forum site... hope to cut cores this weekend also...
s
Old 01-23-2011 | 10:22 AM
  #73
I have decided to finally follow David (Doxilia)'s good advice and embed a piece of 1/32 inch plywood in the trailing edges. I'll use my Unimat to cut a slot at the trailing edge of the rudder:
The rudder will then be carved down to the tapered shape. The 1/32 inch plywood piece will serve as a centering guide, and it will make the trailing edge tougher.
aaaarrrrrrrggggggggg!!!!!!!!!! connection was reset
I'm about to move this thread to that other classic pattern site.
Old 01-23-2011 | 10:28 AM
  #74
I'll try photobucket:
Old 01-23-2011 | 10:34 AM
  #75
The slots:
