View Poll Results: A poll
Voters: 73. You may not vote on this poll
Bridi XLT vs Bridi Escape vs Bridi Great Escape
#151
RE: Bridi Escape vs Bridi Great Escape
David...
It measured the same as the existing header I already own.. actually, my existing ID measured about 23.5mm, and the Rossi says this one id 24mm. If anything, it should have a tad more room...
Do you think 7mm low is still good enough? It clears clears the top of the fuse with some air underneath according to the plans...
MTK...
I like your suggestion and think I may to this providing I cannot find a coupling system...
Brian
MTK...
Brian
#152
It MUST be Christmas in August!!!
I will never build the actual kits, they are WAY too valuable to me personaly. I will be kitting another kit using these parts as templates for each airplane.
A BIG thank you to Jeff (AllTheGoodNamesAreTaken). You truly understand what this does mean to me. Thank you for making this happen for me. I wish I could fly with you. Maybe someday. My RE Super Tigre ought to feel just comfortable under the hood of this bad boy!
This and the Great Escape is the epitome of my hopes in classic pattern building. (I even have kaos plans in the tube between the boxes!)
I have plans for the UFO and the Dirty Birdy. Time to start collecting the Sun Fli series now... I have a set on the way. My collection is wonderfully complete. I think the only thing that will be hard to get now is the Momma Mia plans.
Brian
The newspaper in the box is dated November of 1987... [8D]
Brian
#155
QC, CANADA
ORIGINAL: Ilikebipes
David...
David...
David.
#156
QC, CANADA
Brian
Brian
The Mama Mia plans were published in Model Builder which means they should be available from them - they still sell their plans. Otherwise, if someone has that issue of the magazine, they can be scanned and rendered into something workable. I have a couple of snaps of what was posted in a thread on the model. Interesting comparison between the MM and the DB!
It's possible that Rainedave might have a digital copy of them... not sure. It's a bit of an outrageous model to build for a 60 these days... it would do nicely on a 120 though!
David.
#157
Jeff...
Once again, I am grateful! Thanks for the Sun Fli V plans!
I have the 4 on the way. The 3 is really simple comparatively. I wonder what the 1 and 2 look like....
David-
I am hoping my measurements are accurate. But I think it will work.
My question about the 7mm relates to the plans. I think I'll be fine though. The header looks to sit about 7mm lower than the pipe drawing on the fuse. Actually, I will need to see it when it is assembled. I don't think I'll have anything to worry about...
I should use RTV sealant instead of the silicone tube?
The Mama Mia is crazy... Interesting to see it put next to the Dirty Birdy though!
Brian
David-
Brian
#158
RE: Bridi XLT vs Bridi Escape vs Bridi Great Escape
Hi guys! There is a Bridi Great Escape for sale on Ebay. It's not mine I live in GA, this kit is in TX, just thought y'all would like to know. Here is a link..
http://www.ebay.com/itm/GREAT-ESCAPE...#ht_782wt_1270
Cesar
Cesar
#164
NC
Well...
Who got the Bridi Great Escape???
Show yourself!!!!
Brian
Well...
Show yourself!!!!
Brian
That would be me ... I'm the Great Escape guy. I'm new to RCU and getting back into flying after 15 years out. I have to say I'm appalled by the ARF'ing of the model aircraftindustry, and I'm like many in this forum - IMUSTBUILD! Among my collection of aircraft, I last flew an UltraSport 60 with an OS 61 SF. Superb flyer but not quite fast enough with the long stroke SF. Somewhereon this forumIfound the set of plans for the Desire 60 and am currently putting together materials for that build. In the meantime decided to build a kitfirst, and saw the GE. I've seen Bridi kits since the 80's and this will be my first. Like the look of the GE, prefer thefoam core wings, like thefuse top pipe, and I already have a set of DB retracts. I have an OS 61 RF and Webra 61 RE to choose from, and leaning towards the short stroke Webra for a bit more speed. But a 91 might be even better ...
I've never flown a pattern contest, but I've always thought pattern aircraft were supremely cool, so now it's time to crank out a few!
These forums are great, so much info andso manyideas!
Scott
#167
Well....
I have a great canopy, a new set of 3 gear Spring Air retracts just ordered.. Contest balsa for my wing skins on the way.... Custom cut foam cores... My RE NovaRossi 61 is being bench run and broken in for my by the one and only Mr. Jim Oliver....
Only things I need now are the new "S" shaped header... Servos, on board battery, an AR8000 Spektrum Receiver and a telemetry module with engine temp and rpm sensors..... pull pull, wheels...
Things are looking up! WooHOO! Very eager to fly an Escape.
I am fairly certain my first plan of attack will involve the retract mount to the firewall and fuel tank set up as Mike does his. Gotta get that right this time. Studying his Blue Angel thread pics. Glad they're back!
Brian
Brian
