Curare construction ARG
Felicitaciones por el proyecto!!! Yo también soy amante de los acrobáticos clásicos y tengo pensado construir alguno de los modelos de "aquellas épocas".
Tengo un kit de Kato del Arrow, diseñado por Wolfgang Matt y campeón mundial en 1979.
Voy a seguir atentamente tu post para ver cómo va avanzando ese Curare!!!
Decime de dónde sos, me gustarÃ*a verlo personalmente cuando lo estrenes. Yo soy de Capital federal.
Saludos,
Norberto Stábile
www.deltafly.com.ar
El Arrow es hermoso, espero ver la construcción!
Un abrazo!
Chino
And you are from Begrano? my earliest memories are from there, before my family moved to Brazil.
Un abrazo, Enrique
I think I would do away with the dowl push rod and go with deps instead, I did that on my great escape
http://www.rcuniverse.com/forum/m_72...tm.htm#7246813
Also, Question: The dowel you put on the trailing edge, was that as a guide or for a rounded hard surface at completion?
Your plane certainly will be amazing
Please continue posting ever as you can
Regards
Carlo
Thank you Carlo!
I´m not a pro... I´m just building my first pattern plane with the techniques I´ve learned in this forum.
Regards,
Chino<o></o>
Thank you Carlo!
Regards,
Chino <o></o>
Thank you Vasek! I´ve been building with model airplanes for about 25 years, but this is my firs plane of this type. I have to develop some skills with foam cutting, sheeting, etc. And now the big problem will be finishing this plane.<o></o>
By.<o></o>
Chino
