Go Back  RCU Forums > RC Airplanes > Pattern Universe - RC Pattern Flying > Classic RC Pattern Flying
Reload this Page >
Bridi ESCAPE new build. any tricks or tips would be lovely !
Old 01-25-2016, 10:00 AM
  #126
doxilia
doxilia's Avatar
Originally Posted by MTK
Dave, have you played with larger props and stretched pipe on this mill? I mean, is it capable?
In the 80's we ran the Rossis at around 11k with stretched pipes and 12x12, 13x10 props and 15%N-20%O. More than enough for the 9 pounders of the day, quiet, and terrific gas milage. Some of us used soft mounts but not everyone. It took time to get used to the different sound.
At some point I will build the larger Arrow and it's either the YS or the NR.
Matt,
no no not really. For the purposes of th review I wanted to limit the variables so that I could report and contrast based on some standard. I choose to leave the exhaust factory stock (headers are set for conservative yet still impressive performance) as well as using the recommended fuel (mix wise) and plug.
I suspect that because of its more recent "speed" heritage and high exhaust timing, the engine probably won't be quite as capable as the older Rossi design. I ran it on an 11x10 and a 12x6 and while it was "ok" it certainly seemed like it was better suited and happier turning an 11x8 light prop. It would probably even do its thing happily on a 10x9, 10x10 but not very useful for our application. At 14K-15.5K, it seems to be in its element. The 12x6 wasn't too impressive but I can't quite remember the figures (I'd have to check my article) so I imagine heavier loads would be no better.
If you want to turn a large prop, I suspect the "Classic" (or certainly an AR) will be a better candidate. Although, admittedly, I don't own one (of the new "Classics").
Didnt you sell an AR to Shawn (Speedracerntrixie) for his Dalotel?
David
PS by the larger Arrow, are you referring to the Arrow 800 with fully enclosed pipe (otherwise also referred to as the Granat)?
Old 01-25-2016, 03:00 PM
  #127
MTK
Originally Posted by doxilia
Matt,
David
Dave, thanks for the reply and yes on the sale (older engine that was just sitting) and yes on the 800. The info on the NR is good to know. I tried running a highly timed gas engine at low rpm but in spite of the timed ignition the engine was not happy. I had to run it with a smaller load at designed rpm which was just too high to do me much good.
Old 01-26-2016, 11:22 AM
  #128
doxilia
doxilia's Avatar
Matt,
well interesting thing... I ended up buying the unfinished Dalotel and engine from Shawn as he was moving and needed to part with it. One day I'll finish it up and put it in the air. I actually have been contemplating running it on e-power but we'll see how it turns out on the day.
David
Old 01-29-2016, 08:34 AM
  #129
nappyroots2182
well good news, bad news.
good news is I flew her. its a rocket and flys nicely. other good news is me and my brother just scored a MK blue angel for me and a unidentified pattern ship for him. they said its a compensator but its hard to tell. both are rtf and fairly nice.
bad news is my escape is so damn heavy Im bending landing gear. I can easily save 2 lbs by making new elevators and rudder out of something lighter and covering them, and doing that I can take out a lot of nose lead I have. but ill still be way heavy. other option is to remove all the paint and cover the plane. I need to think about it some more. maybe just fly it and build another nicer one next year. photobucket is down right now so ill get a few pics soon
Old 01-29-2016, 08:35 AM
  #130
computermonkey
My Feedback: (90)
By chance did you get a weight?
Old 01-29-2016, 08:48 AM
  #131
nappyroots2182
Flying weight with lead...13 3/4 lbs
Old 01-29-2016, 08:54 AM
  #132
flywilly
My Feedback: (121)
Landing gear struts are 5/32"? you could go to 3/16" - doesn't solve the weight issue, but will reduce the bending problem. It was a popular (maybe necessary) upgrade for many of the 11lb (or more) EU1-As that I competed against 35 years ago; most were flying from grass fields, too.
There is also the option of using your ailerons as flaps if your radio has the capability to do so.
Old 01-29-2016, 11:17 AM
  #133
nappyroots2182
I'm going to get robostruts. That should take care of the gear. I can get a few pounds of weight off with out starting over with a few mods. I might try before getting real drastic.
Old 01-29-2016, 11:51 AM
  #134
MTK
10 pounds, 60 ounces. That's a lot heavier than I expected. Back in the day these were coming in at 10 1/2 pounds after many mods. A few, very few, were a little less.
At the beginning of your thread some long timers had some advice you may want to heed on a second if you do decide. On finishing, I wouldnt use that grey balsa filler. That stuff is very heavy. Straight glasswork would have been lighter and doped silkspan even lighter. Plastic film would have been the lightest. Good luck with it.
Old 01-29-2016, 12:34 PM
  #135
doxilia
doxilia's Avatar
How many of those 13.75 lbs are lead? I assume whatever battery you are using is all the way up front? What about servos, up front too?
That is a lot of weight. I can't imagine how it got up there but this model can be built to 8.5 lbs all up. Probably even 8 lbs dry with some light cores and 1/32" skins. Kevin's Deception is 7.5 lbs dry and it's a model that's no smaller than this one and it's all in paint. Granted, he's using a CF pipe and a YS which is ~120g lighter than the NR. Still, you need that NR weight up front so nothing wrong with that. Probably just too much dense & thick wood.
That said, congratulations on the maiden and glad to hear you're enjoying her
David
Old 01-29-2016, 01:03 PM
  #136
nappyroots2182
I have the battery under the tank plus 25oz of lead. I can get rid of the weight if I build light elevators and rudder and maybe move the engine foreword an inch. Then I'll be 11ish. That's the first plan before getting crazy and stripping or building new. It was a fun build and my first painted plane. I'm happy it flies.
Old 01-29-2016, 07:22 PM
  #137
stuntflyr
stuntflyr's Avatar
We used to use featherfill on Unlimited race planes to profile the wings but I think you found out it's a tad heavy for use on models. Pretty paint job.
Chris...
Old 01-30-2016, 03:25 PM
  #138
nappyroots2182
my blue angel 40 and brothers plane we just got. they said the red one is a southern rc compensator but I'm not sure it is. both should be fun with a little cleaning they will fly as is
Old 02-20-2016, 12:02 PM
  #139
nappyroots2182
I just stripped the escape down to the bare wood. Everything on the scale is 9 1/4 lbs. So I'll be still almost 11 once finished. Really don't know if I'm going to finish this plane again. It's still going to be heavy. Might just restore my blue Angel now. I don't know how you guys get a plane that's pounds lighter. My wood wasn't that heavy and I'll built it box stock and not over built
Old 02-20-2016, 03:51 PM
  #140
Jim Oliver
Two magic ingredients.......sandpaper and elbow grease
Sometimes the sandpaper is wrapped around a Dremel sanding drum.........
Old 02-20-2016, 04:19 PM
  #141
nappyroots2182
Don't need to remind me about elbow grease. She's bare now :/
Old 02-20-2016, 04:44 PM
  #142
stuntflyr
stuntflyr's Avatar
Car painter and heavy model finishes, Hmmm...
Old 02-20-2016, 06:02 PM
  #143
nappyroots2182
Going to cover in white solartex and only paint the orange on now. Should save a bunch of weight
Old 02-20-2016, 06:40 PM
  #144
Jim Oliver
I saved about 10 oz. on my wing by cutting out rib bays outboard of the retract wells---details available if you're interested.
Old 02-20-2016, 07:02 PM
  #145
nappyroots2182
Did you only cut the foam or sheeting too. I'd like to save more weight, but I'm not fond of seeing the open bays. Got any pics ??
Old 02-21-2016, 02:57 AM
  #146
doxilia
doxilia's Avatar
I think Jim's idea is a must on this bird. Appearances aside, I have the feeling the wing is too heavy as it is given the reported weights. Should be 26-28 oz max but it's probably in the mid 30's. The 1/2" thick ribs will deliver the numbers. 10 oz is substantial on a wing that ought to be light for good performance. The stab could probably receive a reduced but similar approach.
It appears that the fuse top could also receive another good dose of sanding. I don't think I'm seeing any exposed tristock. It really just needs to grip sufficiently the top and sides to avoid it falling apart. Everything else is dead weight and a "boxy" look. I'd hit it with a sand bar and "shoe shine" it with 400 before covering. Likewise on the tail boom bottom if doable. Hollow out any unneeded wood in the front top block under the header.
Nice job on the stripping!
David
Old 02-21-2016, 06:51 AM
  #147
Jim Oliver
Nappy,
No pics of the process but I will take and supply measurements if it would help.
After the wing cores were sheeted I drew rib bays and then attacked the wing with my Dremel sanding drum; went all the way through the wing in most of the bays. Left the "ribs" 3/8" wide, look sorta like wide cap strips.
I didn't do any cut outs in the stab but did sand the sheets really well--could have used 1/32" sheeting instead.
On the vert stab and rudder, I removed half of the material used to frame up the parts (made all the "holes" bigger).
Big opportunity to remove weight on the fuse-----lots of rounding on the corners as Dave mentioned. Hollow blocks to about 3/16" thickness if you can get to the inside. I also used the Dremel drum to remove most of the inside of the ply formers at F2 and F3.
I made a new firewall of 7 ply 1/4" (just tall enough to contain the lightened nylon mount, with about 1/4" excess above the top and below the bottom of the mount). I used firm 1/4" balsa to make the finished firewall conform to the top and bottom outlines of the original firewall.
Some smart --- once said "In a perfectly designed airplane, every part should break in a crash".....
Old 02-21-2016, 07:11 AM
  #148
nappyroots2182
Good info. I didn't round the top of the fuse more because the canopy was almost wider then the fuse already. I'll try to round just a bit more. My fin and rudder were built out of less stick before sheeting then so I'm going to cut them back open. I'll go measure and look into cutting open bays in the wing. Without building a new plane I can't lose much weight anywhere else. The wing seems to be the last area I can easily get too. I might scratch build another escape next winter.
Old 02-21-2016, 03:49 PM
  #149
nappyroots2182
Opened up the bottom only. I really didn't want to see open bays from the top. It took off 3oz. Empty wing is 2lbs. I'm ok with that.
Old 02-21-2016, 07:18 PM
  #150
doxilia
doxilia's Avatar
A 32 oz wing is better. It was in fact at 35 oz as I expected before the "ribbing". With careful selection of wood and diligence with the glue, you can build an Escape wing at 6-8 oz less. Some guys even pull off 22 oz wings but 24-26 oz is more common. Over 30 is considered heavy. The fuse can probably be built to a full 16-20 oz less.
I'm sure that 2 lbs of the model are due primarily to the wood density and thickness and perhaps a little too much glue here and there. An 8 lb Escape is doable. We have a builder over on RCG who just pulled off a 7.5 lbs all up EU-1A which has a glass fuse and is all painted. Most guys back in the day were building them to ~10 lbs... The EU-1A is a big plane compared to most classics.
David
