A plane from the past
My Feedback: (76)
Here's my new SPA plane I just finished. A circa 1975 Patricia. I bought the plans, fuse and cores from Dan at Carolina A/C . I just test flew it for the first time today in gusty winds with an OS 91 Surpass. It flies fast and lands slow at 7 1/2 pounds. When the wind dies down I'll get a better feel for any mixes needed to correct for knife edge etc. Skip
My Feedback: (76)
I neglected to take any pictures during the build. The plane was really simple to put together. The real work came from glassing and painting. I used Concept paint from Radio South which I was able to buy in small quantities because it's so expensive. I really wish Kand B was still around. It was the best stuff and hard as a rock when cured.
www.klasskote.com
Skip, I am currently painting with the above products. Very similar to the old K&B. Good service and prompt delivery.
My Feedback: (76)
I have some Klass Kote here but have not had the opportunity to use it. I will try it on my next plane. I think the drying qualities of that paint differ somewhat from the old K and B (slower). I have been told that other than that they are very similar. I'll try anything for a good result.
ORIGINAL: Sport_Pilot
My preferance is plain old acrylic laquer myself. Though it does fade with high nitro fuels.
Just ordinary rattle can acrylic laquer is fuel proof? At least for 15% and lower fuel? That is something I didn't know and will have to try out. I have a Kadet Senior mostly framed and covered with polyester fabric and was pondering if I was going to get some fresh dope and finish it some day. Now I will have to try this instead.
Do you know if it goes on well over nitrate dope?Mark
ORIGINAL: jquid
Pretty much only Nitrate dope over Nitrate dope. Everything else I tried peeled righ off.
Mark
ORIGINAL: mmattockx
Mark
ORIGINAL: mmattockx
That's too bad, it sounded like a good way to finish the Kadet without buying a bunch of dope and pulling out my compressor (I moved recently, so things are a bit unsettled...). I guess it will be dope all the way for the Kadet.
Mark
ORIGINAL: jquid
Mark
Carefull with the rattle can stuff, read the fine print and make sure it is 100% acrylic laquer. I quickly painted a 1/2 a C/L plane with rattle can Plastikot truck an van paint, for my son years ago. Despite having fuel all over it the paint held up well. The competition C/L stunt guys use it all the time, it goes over nitrate dope, as well as butyrate. But ususally they apply one to two coats nitrate as a sealer, three to 10 coats of aluminum butyrate as a sealer, sanding the dope till the wood shows on all but the last coat or two.
Mark
Mark
No laquer. The enamel is not fuel proof.
Mark
