Venom Build
#52
Congrats on the completion and successful flight test. I have to give you [sm=thumbup.gif][sm=thumbup.gif][sm=thumbup.gif] and I hope we get to see a video of it real soon.
What's it's ready to fly weight?
#53
AL
I don't have the ability to do Video sorry.
It ended up at 6.25 lbs. It is a real rocket. It goes straight up and straight down at the same speed. I love it, it is one of the best flying planes I have ever had.
#54
AL
In case anyone is interested the ST 91 is running an old Hatori 650 pipe. I am getiing 14,800 RPM on the ground with an APC 12x9 prop and 15% Omega fuel.
#57
ORIGINAL: Paternguy
knife edge is a plus. I would like to see a copy of your plans also.
#58
AL
It is in Visio format, but I am sure that any local print shop will be able to print it for you.
I guess I need to write up some construction notes too.
#59
ORIGINAL: Paternguy
I totally forgot my manners with the last post, too. Great looking plane! 6.25lb with a piped ST91 is fantastic, I know what that engine will do with 8lb models on a muffler, I can't imagine what yours is like...[X(]
Thanks for the effort to design a new ship and then share it with everyone via this thread and the plans,
Mark
#60
AL
Unfortunately I did the plans in Visio basic and I don't have the ability to convert it to anything other than VSD. If there is anyone who has the ability and wants to convert it, that would be ok by me.
#61
My Feedback: (19)
OH
ORIGINAL: Paternguy
Just want to confirm this - you have a 12x9 approaching 15K peak ground rpm ? I ask because, by enlarge, that is somewhat beyond the capabilitites I have had a ST91 demonstrate. Might be some magic with the 650 - just want to confirm.
#62
AL
Thats correct, I was shocked too, I checked it several times. Maybe I just got a good one. LOL
I was OK with the weaker performance, after all it was a cheap engine.I was getting 13,500 on a 12x8 before i put the pipe on it. This engine (at least the one I have) was definitely made for a pipe, it has really come alive.
#63
My Feedback: (19)
OH
ORIGINAL: Paternguy
Both the ST91 and OS91 are little more thank over-grown .61 engines - they really perform well on the same conventional "60" size props. From what Ive seen, too many guys over-prop these. Sometimes with disapointing results. Although the best I was able to get from the ST91 was about 13K on a 12x8, with the jett muffler. The OS 91 runs about the same, both prefered the 12x8. The H-650 deep-baffle setup appares to provide a great deal more boost. I may have to play with it again.
#64
AL
This is the new "Chinese" version of the ST 91. I have noticed some visual differences between it and my older versions. The first one I noticed is that the exhaust port in the liner appears to be slightly taller ( more duration) I attribute the extra pipe performance to this.
Also the opening the spray bar on the carb is wider but more narrow. The needle valve also appears to have a more aggressive taper to it as well. This may be creating a more efficient fuel air mixture.
I am a complete amateur at this I am just applying what I remember from physics class in college.
#66
ORIGINAL: Paternguy
Mark
#68
ORIGINAL: Paternguy
I have tried several times with no luck.
Mark
#73
AL
So I decided to build another Venom. But after looking at her and looking at the original Mach 1, can you guess which direction I went in ? LOL
Although the Venom flew great, it was a bit of an ugly duck. LOL
So here is what I have so far, let me know what you think.
#74
HI
ORIGINAL: Paternguy
I would love to have one w/ retracts, clear conopy, and a pipe tunnel kind of like an Atlanta. Where the tunnel dosen't quite blend in with the fuse but has a personality all itself.
Venom an Ugly Duckling?? Not to me, I like it!
DM
