Motor Mount
MS
I was able to find a NIB ST Bluehead, one slightly used Bluehead and a NIB G60. I intend to use the Bluehead in my Southern R/C Tigertail. I'm rounding up the hardware before construction begins and have the Southern R/C-Dave Brown retracts ready. However, I'm looking for a solid metal motor mount and it appears nobody makes them anymore. I can find composite mounts which I really would rather not use and I can find the soft mounts which I've never used and Clarence Lee shuns.
Question- Does anyone know of a solid metal motor mount available? ( The OS .61 mount comes predrilled and the holes don't match). and, 2. Will I see any performance issues with a soft mount?
Your input would be greatly appreciated.
Frank
Frank
Hi
I now u said u didn`t want to use a soft mount.
But the mounts from dubro are soft mounts but don`t shake all over the place i got one mounted in a deception and i like it.
http://www2.towerhobbies.com/cgi-bin...&I=LXD631&P=WR
Grtz Erik
Grtz Erik
My Feedback: (14)
ORIGINAL: stiletto660
What was Clarence Lee's concern? Power loss?
Power loss and parts loss. Many glow engines shed screws, nuts and bolts when soft mounted.
If you are flying contemporary pattern, you have no choice. You must use a soft mount to meet the sound requirements. However, flying older pattern ships in SPA and similar events does not require the extra weight and constantly changing thrust angles that a soft mount imparts. I avoid soft mounts like the plague.
