Phoenix 6
Old 11-07-2007 | 05:37 PM
Default Phoenix 6
Anyone know where I can get Don Lowe's Phoenix 6 plans?
Michajon.
Old 11-07-2007 | 07:48 PM
My Feedback: (15)
Default RE: Phoenix 6
Is this an all balsa buildup ?
ID:	799054   Click image for larger version
ID:	799055   Click image for larger version
ID:	799056   Click image for larger version
Old 11-07-2007 | 08:13 PM
My Feedback: (8)
I thought the Phoenix 6 and later were fiberglass fuse with foam wings. Although I would love to be wrong about that. I have seen a magazine plan for the Phoenix 5 that is all wood. Give me some time and I can tell you which one...
turbo
Old 11-07-2007 | 08:15 PM
My Feedback: (10)
It is likely a fiberglass fuse.
I have a Skyglass Phoenix 5 fuse, so you could get the 5 in glass also.
Jeff
Old 11-07-2007 | 08:21 PM
My Feedback: (15)
Hey Turbo - Phoenix V and VI, glass and foam. I have the plans for the original, maybe same mag article you have, and not in blown up form. See these attached. A VI and an VIII.
Vince
ID:	799081   Click image for larger version
ID:	799082   Click image for larger version
ID:	799083   Click image for larger version
ID:	799084   Click image for larger version
Old 11-07-2007 | 08:23 PM
My Feedback: (15)
Wing Mfg. is going to kit the Phoenix V. Glass and foam. Don Lowe has flown the prototype, so it's a go.
Old 11-07-2007 | 08:39 PM
My Feedback: (8)
Crankpin, you are correct! The magazine is American Aircraft Modeler (July 1975) for the built all wood up version. I had to look it up to be sure. I hope Wing Mfg comes thru with several of the designs the got the molds to..
turbo
Old 11-07-2007 | 09:13 PM
I have the Phoenix 7 that is glass, I assumed the 6 or 5 was built up but I don't know for sure. Hope it gets kitted, thanks for all the info
Michajon
Old 11-07-2007 | 09:20 PM
Thanks for the info guys. I have the Phoenix 7 in glass, but I don't know about the 6 or 5, they may be glass also. A friend of mine had a Phoenix he bought from a shop (already built and flown) but never met the original owner. He was told it was a 6 but that might have been wrong. It had foam wings and fuse top, the rest of the fuse was wood. Hope the kit does come out, thanks again,
michajon
Old 11-07-2007 | 10:10 PM
rainedave's Avatar
The AAM P5 plans show a foam wing and balsa fuse.
David
Old 11-07-2007 | 10:15 PM
rainedave's Avatar
In fact, this would be a good candidate for my latest engine, an ST Bluehead that has both STS porting and PDP slits. I haven't run it yet, but it's supposed to be one of the stronger ones.
David
ID:	799170   Click image for larger version
Old 11-07-2007 | 10:42 PM
Where can I order the plans?
Thanks again,
michajon
