Jekyll
Old 12-13-2007 | 07:53 AM
Default Jekyll
Does anyone have any info on this plane?
No plans. I don't think it was ever a built up plane, just f/g and foam. I have one and I need to know the basics, surface deflection, thrust line, cg, etc.
DM
Old 12-13-2007 | 09:41 AM
CGRetired's Avatar
Default RE: Jekyll
Looks like you also need a right-side horizontal stab, DM..
Old 12-13-2007 | 09:50 AM
Default RE: Jekyll
this plane was wold champion in 1991 or 1992... one of the first of the new era... the first "square" airplane... it s a precious thing...
Old 12-13-2007 | 11:29 AM
My Feedback: (18)
Default RE: Jekyll
Sooo you need the Dunphys phone number or e-mail address...I'll bet they could help if no one else can...I'll try and search for it and post it here...Brb..
Haaaa..Was one of your older threads:
http://www.rcuniverse.com/forum/post...966&toStyle=tm
Old 12-13-2007 | 05:14 PM
My Feedback: (121)
Default RE: Jekyll
Hi DM,
First, the Dunphys (PAC) are no longer kitting pattern ships. In fact, they are selling the molds, templates, etc. that they currently own. You can email them since they do have some parts left in stock.
Flyingfoam.com can cut you a replacement on their CNC cutter. You will need to provide an airfoil (or x-section that can be scanned) and dimensions (there's a form on their website).
Good Luck,
Will Bartlett
Old 12-13-2007 | 05:25 PM
My Feedback: (18)
Default RE: Jekyll
Delete...
Old 12-13-2007 | 06:20 PM
Default RE: Jekyll
I have a new kit in my collection,it came with 2 sizes of wing cores.Let me know how I can help you
Rich
Old 12-13-2007 | 06:51 PM
Default RE: Jekyll
ORIGINAL: 70s Flyer
Rich
RICH!!!
I actually need the literature for the plane. I have nothing. The plane "looks" finished, but it isn't even up to an arf yet. Luckily I do have that other stab half in perfect condition. I want to make this plane have removeable stabs (only makes sense due to the condition). I need to know all the building info.
BTW... No comments on the covering???
DM
Old 12-13-2007 | 07:24 PM
Default RE: Jekyll
1.5 deg.right thrust 1deg.down thrust C/G is inline with the front edge of the wing tube.The fusleage plan is in a 1/2" to 1" scale.The wing is full size. I can send you a copy if you want.
Old 12-13-2007 | 07:25 PM
My Feedback: (18)
Default RE: Jekyll
ORIGINAL: vintageflyer
I love the covering!! Only Real Men Fly Pink!!
Old 12-13-2007 | 09:14 PM
Default RE: Jekyll
Pix of the plans
Old 12-13-2007 | 09:16 PM
Default RE: Jekyll
Try this again
ID:	825077   Click image for larger version
Old 12-13-2007 | 10:06 PM
Default RE: Jekyll
ORIGINAL: 70s Flyer
Try this again
Can you tell me how many formers are in the fuse. That thing is like an egg shell--Scary Light!
Like I said, I have a lot to do on this one til I get her up in the air.
Do you have anyway of scanning the plans?
DM
Old 12-14-2007 | 12:56 AM
My Feedback: (18)
Default RE: Jekyll
Hey...I have a Prophecy Kit...I could see if I can scan some of that information if you like...The Prophecy is a 2meter Aircraft and is a decedent of the Sequel...The Sequel is a decedent of the Jekyll...There were of course changes incorporated form the Jekyll to the Sequel...And more from the Sequel to the Prophecy...The Prophecy's thrust line and wings are higher than the Jekyll...Most of the numbers on the prints will not be of any use to you...
But I was thinking you could probably use some of this for "reference"...For instance you could take a look at how many formers were used...Their placement...How they laid out the radio gear and fuel tank ect...Who knows...You may even be able to trace the Fuse former templates and cut them down a little to make them work...It may be a little easier than starting with Nothing??
I still think you should call the Dunphy's...I'd be willing to bet they have the information you seek for the Jekyll...I knew they are no longer producing kits...But I feel certain they've got the "data"
So I'd have to figure out how to do the scanning thing again...It's been a while since I used my scanner..he he
But if you think you might benefit from any of this please let me know...
Chuck
P.S. In these pics you will notice some black stripes in the fuse...That is Carbon Fiber Tow...On the Prophecy..In addition to the firewall and rudder closeout...There are a total of 4 fuse formers which will be installed (2 in the aft fuse area)...The Jekyll may not call out any fuse formers?? I don't see them on the print?? You could always add some CF tow to stiffen things up if no bulkheads are required...
ID:	825256   Click image for larger version
ID:	825257   Click image for larger version
