Another Blue Angel build
#102
RE: Another Blue Angel build
Vacuum bagging is a simple and extremely effective way to do many things in this hobby, including sheeting foam. For all of you who still build models, it's a worthwhile technique to learn. I place only the sheeted wings in the bag, not the whole assembly. Once vacuum is applied, the bag is placed on the husk and left there to cure. The outcome is as accurate as the cut foam was to begin with. Compression is extremely consistent throughout so there's very little chance for warps to develop.
MattK
MattK
#104
ORIGINAL: dhal22
matt, i believe you, just never got around to building a vacuum device.
david
david
MattK
#105
My Feedback: (18)
GA
ORIGINAL: dhal22
david
david
You would need a regulator for skinning wings but that wouldn't be a problem...I've only used for making parts so it's set up for 100% debulk...I was going to get a regulator for doing wings but havn't got around to it yet...
Have Fun...
Chuck
#107
filling in the retract areas using 1/64 birch ply and balsa. also exposed the aileron servo pockets. i plan on using a couple of aileron servo panels from an arf that expired long ago. just goes to show you there are uses for arfs.[X(] soon to have a full wing. i can't wait.
david
david
#110
ORIGINAL: dhal22
david
david
Hopefully you reinforced the bottom skins adequately before you skinned. That many cut outs on the bottom of the wing could be a strength problem. I am talking from experience and on the one that failed on me, the skins were 3/32" and the wing was fully glassed. I admit to some fairly snappy snap rolls doing the wing in so if you don't fly crazy you may be ok, but better safe than sorry.
One way to get strength back at the cutouts is to lay down a layer of 1-1 1/2 oz cloth first and then glass with the 0.6 oz cloth. Or altrenately, a layer of 0.5 carbon mat then glassing as usual
MattK
#111
thx, any lightweight strength advice is always welcome. anyone else have a foam wing failure because of retract/servo cutouts? i did not use any spars or carbon strips under the skins.
thx, david
thx, david
#112
Mattk, i used Probond polyurethane to glue the skins to the foam. an extremely strong method as the expanding glue injects itself into the foam and wood. i don't know what method you used on your failed wing but the poly glue method is a heck of a lot stronger than the 3M adhesive spray method i used in the 90's. i think i've got a pretty strong wing here. please no offense taken here at all.
david
david
#114
ORIGINAL: dhal22
david
david
The pundits will say it will never happen. My point is it can and it will given the chance. You may never have a problem but you might, and it might ruin your day. Up to you.
Since going to conventional gear set-ups and plug in wings, the issue has never re-appeared. But then again, loading is lower and construction technique has improved from 20 years ago. The tube socket is installed using 1/8" thick 15" long balsa subspars top and bottom along the length of the socket (spanwise) and the sheeting is glued flush on the subspars. Very light and strong and highly recommended method for those wing types.
Not a help for the Angel tho since it's 1 piece wing.
BTW, 1-piece wings can be built easily with sockets and can be pull apart twin panels if one desired such a set-up. Just as light as the glassed center section types and with the added convenience of pull apart features for easier transport.
If there's interest, I can outline the technique I developed around the time we transitioned to plug in wings (20 years or so give or take)
MattK
#116
don't know why i go through long layoffs on my projects. i needed some thick wood for the wingtips (my order of balsa from national balsa has been disappointing) so that was part of the downtime. i ended up laminating the wingtips and adding a 1/8 lite ply center section for dent resistance. being too aggressive on lightening holes caused me to build a 2nd set of wingtips. more shaping is still to be done but i'm getting there. i also decided to try to line my engine opening with 1/64 birch ply. it should neaten up the opening once i get to the glass and paint stage.
#118
i'm starting to get behind on updates. since there are other places to get step by step construction tips i will skip to a couple of recent photos. i have shaped the ailerons (8178 style), finished the wingtips (except for final sanding), completed the wing mounting to the fuse and i am getting close to having the belly pan shaped.
#119
Hey David,
You don't want to know what us loyal thread followers do to people who get behind with their updates......[>:]
At the rate you're going, you will be ready for paint in no time. Keep up the good work[sm=thumbs_up.gif]
#120
i should finish the belly pan later today and then what? rear stabs need to be attached and then i really am getting close to glass time. more later.
#121
PA
Man is that looking sweet!!
"line my engine opening with 1/64 birch ply" I am going to have to steal that idea , that cleans up the opening perfectly.
Awesome build !!!
-Jason
Awesome build !!!
-Jason
#122
ORIGINAL: zubba
Awesome build !!!
-Jason
Awesome build !!!
-Jason
since it worked so well i'm thinking about doing the same thing with my nose gear retract opening. there is a lot of blue filler in the photos (i don't build as tight as some do), it is evercoat rage lightweight body filler. it's ready to sand in 3-5 minutes and very easy to sand. i like to use the regular balsa colored filler also but it takes a lot longer to dry. of course the color won't matter after fiberglass and paint.
#123
more belly pan work. it is all filled in and ready for final sanding. i painted a coat of watered down hobbylite over the balsa not covered by evercoat. it makes for a super smooth finish after sanding. i did the fuse that way and was very happy with the results. i will 'paint' the balance of the wing that way next.
#124
Nice work there Daid,
Realy like the engine bay, A finished edge like that when painted will look realy great ( like a fiberglass fuse)
I'm also going to get some of that evercoat stuff, How is on weight?
