Deception or Tiporare?
Old 01-09-2008 | 12:36 AM
Default Deception or Tiporare?
I am getting some cores cut in the next few weeks and I am thinking of getting a set of cores cut for one of the above planes. I have plans for both, so which one should I get cores for? I am leaning towards the Tipo, but I think both are great models. Power will be a ST90 side exhaust engine if that influences anyone's thoughts.
Mark
Old 01-09-2008 | 07:40 AM
8178's Avatar
My Feedback: (17)
Default RE: Deception or Tiporare?
I’ve read that the Tiporare was/is the most popular design of the ballistic pattern era. It takes tri gear retracts very well too.
Old 01-09-2008 | 08:54 AM
rainedave's Avatar
Wasn't there a scaled-up Tipo (the Hippo?) that would be a good choice for your .90?
David
Old 01-09-2008 | 08:56 AM
Both aircraft are fine flying aircraft. I personally have not flown a Tipo, but, I have scratched and successfully flown the Deception. Jim Kimbro designed and built a nice flying plane. At the time I used a Webra Speed Rear Exhaust 61 with a OPS tuned pipe, with mixture control. The plane was very solid in all the manuvers. and yes it landed "hot" as it was a "slick" aircraft. I still have a set of plans,canopy(UFO style) and the Webra "pickled" for a future Deception. Hummmm !
Either way you will do well.
Old 01-09-2008 | 10:03 AM
Skylane's Avatar
Mark,
I competed in the 80's with two Deceptions and a Tipo, in that order. Both designs are excellent. My Tipo was somewhat lighter than the Deceptions since I Monokoted the wings and stab as compared to the balsa/foam Deceptions which were glassed and painted. Also, as time went on, I moved to progressively more powerful engines - the Tipo had a Rossi and then a YS60 while the Deceptions had a Super Tiger X-60 and then Webra Speeds. The difference in weight and power makes a detailed comparison impossible, but I loved them all. I am currently building a Deception from plans and I will be taking pains to build it lighter (and straighter) than my previous efforts. I am also contemplating a Tipo for my next plane. Where did you get the plans?
Jeff
Skylane N9214G
SPA 243
Old 01-09-2008 | 11:55 AM
ORIGINAL: rainedave
David
The ST90 is the same size and weight as any of the current 60's (20.7 oz without muffler), so it's not an issue for me. With a Jett muffler it turns similar RPM as many of the screaming 60's and can also compete with the early long stroke 60's on the bigger props (on a standard muffler, not the Jett). I think the Hanno Special was a bit stronger, but it also ran a full pipe compared to the 90 on a muffler. I am going to be running in a NIB 90 this spring and I am going to try an experiment with a mousse can pipe on the stand to see how it does with that instead of a pipe or muffler. It may become my standard exhaust for the 90 if it works, it should give excellent performance and weigh almost nothing. I had a ST90 on a CG Ultimate bipe years ago and it ran very strong until I dumb thumbed it into the dirt one day. These engines are a well-kept secret, being very reasonably priced and running strong. If you are not stuck with a displacement limit and can live with the side exhaust configuration, they are a great deal.
Skylane, I bought the Deception plans from MAN and someone sent me a scan of the Tipo plans (I can't recall who, it was a couple of years ago).
Mark
Old 01-09-2008 | 04:52 PM
I had 5 Tipos when it was in its prime. It was an excellent airplane Never had a Deception, but it comes down to personal preference ay this point.
There was also a Hippo Tipo. I think it was around 1981 time frame. I think Don Weitz flew one that year. It was also a Dick Hansen creation.
Old 01-09-2008 | 10:56 PM
WEDJ's Avatar
Having had a Tipo 750, and being very succsessful with it, I vote Tipo. Never flew a Deception, but it is highly regarded. Photo of my Tipo below - yes, it has the old Taurus paint scheme, it is very visible in all air conditions.
Old 01-10-2008 | 02:12 AM
My Feedback: (14)
I'm with you. I prefer the Tiporare (standard size).
I built/flew/trimmed and eventually abandoned a Deception. In a dog fighting world of Japanese Zeros, ME-109 and Spitfires, the Deception was the equivalent of the P-47 Jug. Great for ground attacks and other strafing duties, but too heavy and awkward for intimate dog fights with lighter, tighter turning airplanes. Just my opinion.
Ed Cregger
Old 01-10-2008 | 01:08 PM
ORIGINAL: Ed Cregger
<snip>
Just my opinion.
Ed Cregger
Opinions were what I was asking for, Ed. You have nothing to worry about here.
I think you guys have sold me. I was leaning towards the Tipo anyway, and all the positive comments are cementing it. I have to draw the wing planform and airfoil section for whatever I get cut, if I get time I may do both and get both cut just so I never run out of building projects in the middle of a long winter stretch. Yeah, like that will happen...
Thanks for the input guys,
Mark
