Classic Pattern Kit Needed
Old 07-30-2008 | 11:57 AM
Default Classic Pattern Kit Needed
Greetings everyone,
Thanks to a fellow RCU member, I am the proud owner of a NIB Rossi Fire 61 rear exhaust!!!!(Thank you pgilbert). So, I am now looking for options as far as what kind of plane to put it in. It came with an offset header and tuned pipe so I am thinking about finding a plane that I can hide the pipe in the fuselage. What do you gentlemen think about this motor in a Bridi XLT? I have the Dirty Birdy 60 kit from Bluejay and I like the quality of the wood in the kit. Does anyone have any other suggestions with regards to a plane? If possible I'd like to find a kit that is readily available with built up wings (since I don't have any experience with sheeted foam wings). I did see however that the XLT has sheeted foam wings.
Thanks in advance for your help.
Old 07-30-2008 | 12:29 PM
My Feedback: (18)
Default RE: Classic Pattern Kit Needed
Awww...Might as well take the plunge into the foam core world...Although I've never flown one I think the XLT should be a fine choice!!
I have a Bridi Escape kit which I believe is very similar to the XLT (I think the XLT is a little bigger)...Should be a straight forward build with no major hurdles except learning to sheet wings which shouldn't be a problem...
I've been told to choose light (contest grade) 1/16 balsa to sheet the escape wings rather than the factory recommended balsa sheeting (3/32 i think??)...
I would imagine your Rossi and XLT combo would be a really sweet set-up!!
Good Luck in your decisions...
Chuck
Old 07-30-2008 | 12:31 PM
rainedave's Avatar
I've been doing the same kind of brain storming. I recently got a Webra Speed rear exhaust, myself. I was thinking about Dan Hine's T2-A MK II. Upright installation, no regulator or pump necessary.
David
Old 07-30-2008 | 12:34 PM
My Feedback: (18)
I was just about to edit my post and bring that airplane up...lol
I like the T2-A MK II...I believe that would be a glass fuse and foam wing type of kit..Is that correct??
Good one..
Chuck
Old 07-30-2008 | 12:35 PM
rainedave's Avatar
I've also been messing around with tracing the Escape in CAD. Dynamic Balsa has the wing cores. The fg canopy would require the most work.
David
Old 07-30-2008 | 12:41 PM
My Feedback: (18)
ORIGINAL: rainedave
David
Canopy is no problem...I'm splashing mine to make a lighter/better one (suppose to have it done already... )
It's all set-up I'm just kinda waiting till I have some other glass work going...
Old 07-30-2008 | 01:02 PM
rainedave's Avatar
Will you please make two?!
I'll PM you about this.
David
Old 07-30-2008 | 04:07 PM
Back when I was flying an Escape in the early 90's I trashed that ugly canopy/pipe cover for a compensator canopy. Now that was an interesting-looking airplane!
Edit: And make sure you watch the weight on either of these planes, they get heavy very quickly if you're not careful.
Old 07-30-2008 | 04:50 PM
My Feedback: (18)
I gotta admit...I think that T2-A MK II is allot nicer looking airplane than the Escape or XLT...
Old 07-31-2008 | 07:04 AM
Hey Fella's,
I've been thinking about getting an EU1A from Deadstick when they are available. Its a fairly large plane and I've gotten mixed results when talking to a couple of people on whether or not the Rossi will have enough power for the plane. What do you guys think? Maybe I'll give Deadstick a call and ask him what he thinks.
Keep the suggestions coming.
Old 07-31-2008 | 08:35 AM
rainedave's Avatar
Don't forget to browse through casniffer's image database for inspiration:
http://www.trentonrcflyers.com/pattern/patterna.htm
David
Old 08-02-2008 | 07:25 AM
rainedave,
Check your Nimbus 2 plan in the database, the date on the plan and the wing belong to Perigee/Apogee.
Evan.
