Mach 1 Laser Kit Build
Old 04-05-2009, 03:44 PM
  #101
Pattern One
My Feedback: (73)
Pattern One's Avatar
Default RE: Mach 1 Laser Kit Build
Hi Guys,
The stab has been sheeted on both sides, stab tips have been added. The LE and tips still need to be shaped. Things are moving forward.
Leo
Old 04-05-2009, 03:50 PM
  #102
Pattern One
My Feedback: (73)
Hi Guys,
Sorry, I forgot the pictures in the last post. I spoke to Dan at Laser Tech today. Based on the emails and PM's he has received it looks like after the Sequel and Sweetater we can expect the Tiporare, Curare, Arrow, UFO, and Compensator. Dan released the beta kit on the Sweetater a year ago and it went together very well. He also has the Atlas ready to go. Dan said he will be doing all of the popular designs for himself and will make them available as he does.
Pictures of the Mach 1 stab attached.
Leo
ID:	1173279   Click image for larger version
Old 04-05-2009, 06:22 PM
  #103
ccpetersen
ccpetersen's Avatar
Looking good Leo,
Is Dan considering getting a web site so we can peruse his great works and see what's available or in stock? Perhaps even place an order.
Old 04-05-2009, 08:14 PM
  #104
Pattern One
My Feedback: (73)
ccpetersen,
Dan has mentioned the topic of a web site, but I'm not sure what his future plans are. I will ask the next time we talk. My work schedule should be more relaxed this week so I should have time to work on the Mach 1.
Leo
Old 04-07-2009, 08:41 PM
  #105
Pattern One
My Feedback: (73)
Hi Guys,
I shaped the other Elevator, hinged and shaped the elevator leading edges. Tomorrow the Stab leading edge and tips will be shaped, then a final sanding will wrap it up.
glockguy
ID:	1175374   Click image for larger version
Old 04-09-2009, 04:03 PM
  #106
Pattern One
My Feedback: (73)
Hello Everyone,
I finished the Stab today. Pictured you can see the centerline marked out on the leading edge and tips , then the final results. I will give everything another light sanding prior to the glassing process. The Rudder and Vertical Fin are next on my list.
Leo, aka glockguy
ID:	1176715   Click image for larger version
ID:	1176716   Click image for larger version
Old 04-10-2009, 12:24 PM
  #107
Pattern One
My Feedback: (73)
Hello Guys,
I started working on the Rudder & Vertical Fin today. Pictured you can see the parts out on the bench, The LE & TE of the vertical fin sanded to rib profile and the first side sheeted, pinned and weighted down. The Rudder parts were joined. To be continued.
Leo, aka glockguy
ID:	1177240   Click image for larger version
ID:	1177241   Click image for larger version
Old 04-10-2009, 05:52 PM
  #108
Pattern One
My Feedback: (73)
Hello again,
The pictures show the first side of the vertical fin sheeted, the other side sheeted and waiting for the glue to dry, and the fully sheeted fin. Next will be sanding the LE profile, shaping the rudder and hinging the rudder. I made a mistake with the rudder in the last post. The top part should be glued to the vertical fin, not the rudder. I corrected that. More to follow later today.
glockguy
ID:	1177415   Click image for larger version
ID:	1177416   Click image for larger version
Old 04-10-2009, 07:36 PM
  #109
Pattern One
My Feedback: (73)
Guys,
The vertical fin and rudder are finished now except for final sanding prior to glassing. The LE edge of the vertical fin was shaped, the rudder was shaped and the hinges were installed. More to follow soon.
Leo
ID:	1177480   Click image for larger version
ID:	1177481   Click image for larger version
ID:	1177482   Click image for larger version
Old 04-10-2009, 08:47 PM
  #110
doxilia
doxilia's Avatar
Hey Leo,
wonderful job you're doing here.
The size of that rudder, or rather, the size of the fixed rudder portion at the top, caught my eye. I had never realized that the Mach 1 had such a configuration. It's interesting that the Deception has pretty much the opposite configuration with the rudder entirely above the elevators and a fixed lower portion.
BTW, how does that hinge slotting machine work for you? Is it worth the green? It probably makes for fast slotting for CA hinges I'd imagine.
David.
Old 04-10-2009, 09:27 PM
  #111
Pattern One
My Feedback: (73)
Hi David,
The Vertical Fin and Rudder are per plans. I like the "slot machine" it works well as long as you pay attention to what you are doing. It cuts wood like butter. Tomorrow I will work on the wing.
As an experiment I made some new blocks for the fuse using 4" wide stock versus using the glue and laminate method called out in the original Midwest kit. Using the light 4" stock resulted in a total savings of 6 oz. I scraped the original blocks that I had glue and laminated.
Thank you for the kind words.
Leo
Old 04-12-2009, 01:45 PM
  #112
Pattern One
My Feedback: (73)
Hello Everyone,
I cut the engine mounts so the Webra Speed .70 would drop in. Maple is tough wood. I set the engine on the beams and placed the 2 1/4" Tru-Turn FAI Spinner and the nose ring in place. The nose ring was tacked on with rubber glue for now. The installation went well.
Leo
ID:	1178753   Click image for larger version
ID:	1178754   Click image for larger version
ID:	1178755   Click image for larger version
ID:	1178756   Click image for larger version
ID:	1178757   Click image for larger version
Old 04-14-2009, 04:23 PM
  #113
Pattern One
My Feedback: (73)
Hello Guys,
The part number F7's were glued onto the bottom of the engine mounts. You will notice that the nose gear has been bolted back into the airframe. I made the servo mount for the Hitec Metal Gear Servo, installed the servo into the mount, mounted that assembly into the fuse using 4-40 bolts and blind nuts. I made the linkage and tried it. It worked well. I will be routing the servo wire through the tank compartment. More to follow.
glockguy
ID:	1180366   Click image for larger version
ID:	1180367   Click image for larger version
ID:	1180368   Click image for larger version
Old 04-18-2009, 03:51 PM
  #114
Pattern One
My Feedback: (73)
Hello Guys,
I sanded the balsa F7's down to match the motor mounts so the engine would drop in. I milled a slot so that the nose gear steering servo extension could pass through F2. The throttle linkage was set up using a ball link. No issues with the linkage passing through the tank compartment. The 16 oz tank looks like it will work, so far. More to follow.
Leo
ID:	1182699   Click image for larger version
ID:	1182700   Click image for larger version
ID:	1182701   Click image for larger version
Old 04-18-2009, 04:43 PM
  #115
8178
My Feedback: (17)
8178's Avatar
Very nice work! Glad to see the fuel tank fits, I was wondering if you had enough space for it.
Old 04-18-2009, 06:13 PM
  #116
Pattern One
My Feedback: (73)
8178,
Thank you for the compliment. One day I hope to have the skills you do. The Hayes slim line 16 oz tank fits some of the classic pattern planes very well. The top block will be the last issue to deal with for the tank fit.
Leo
Old 04-24-2009, 12:54 PM
  #117
Pattern One
My Feedback: (73)
Hello Guys,
It's time to work on the wing again. I installed the scrap filler blocks along the LE & TE that will help support the 4 wing hold down bolts. They will get their final shape and sanding when the LE & TE are shaped. More to follow.
Leo
ID:	1186444   Click image for larger version
Old 04-24-2009, 03:07 PM
  #118
Pattern One
My Feedback: (73)
Hi Guys,
The sevo mounts have been installed in the wing. I plan to use Hitec HS-85 BB Micro Servos (x2). They have 49 in/oz at 6V. You can see the servo mounting beams pictured and some 3/32 scrap in place to show some detail. More to follow.
Leo
ID:	1186492   Click image for larger version
Old 04-24-2009, 03:38 PM
  #119
crankpin
My Feedback: (15)
I see Kraft-Haye's wheels on your table. Good stuff. You will be happy with your HiTec choice. Looks great Leo.
Crank
Old 04-24-2009, 03:47 PM
  #120
doxilia
doxilia's Avatar
Leo,
you must have done it before if you're planning on installing HS-85's in a Mach 1 [X(]. Of course, they are comparable to muscle servos back in the day but still somehow they'd make me feel like the Mach 1 might only achieve Mach 0.5... Have you considered Hitec's latest digital sports - HS5475? Or even the analog HS-475? You might find this Canadian source great value (with today's exchange rate)!
http://www.greathobbies.com/producti..._id=HITHS475BS
Great Hobbies is kinda the Tower up here - great service.
Old 04-24-2009, 03:55 PM
  #121
doxilia
doxilia's Avatar
Crank, Leo,
does this table look familiar too?
Old 04-24-2009, 04:02 PM
  #122
Pattern One
My Feedback: (73)
Crank,
I try to purchase the Kraft-Hayes wheels when the price is right. A friend of mine is using the Hitec HS 85 BB's in an overpowered "Hots" and they work very well for him.
David,
I do have a good supply of most of the popular Hitec servos, but at this point I plan to stick with the HS 85 BB's. I see you like the Kraft-hayes wheels also. I wish someone would make them again.
I will be working on the Mach1 and SEQUEL this weekend, so stay tuned.
Leo
Old 05-01-2009, 02:55 PM
  #123
Pattern One
My Feedback: (73)
Hi Guys,
I cut the landing gear struts to fit in the wheel wheel area. This is not the final length, but will work for set up. Over the weekend I will be working on the balsa wheel wells.
Leo
ID:	1190193   Click image for larger version
Old 05-01-2009, 04:56 PM
  #124
Pattern One
My Feedback: (73)
Hello All,
I have the Wheel well parts on the bench ready to be joined with thin CA in a Pipette. The parts are joined and shaped around a spray can after they are sprayed with water. More to follow.
Leo
ID:	1190249   Click image for larger version
ID:	1190250   Click image for larger version
Old 05-03-2009, 11:45 AM
  #125
Pattern One
My Feedback: (73)
Hi Everyone,
The retract wells were set in place so you have an idea of what they will look like. They are too deep at this point. Next posting they will be finished and attached to the retract mounts. The air lines will be run too. More to follow.
Leo
