III Perfection
Does anyone have RCM Jan 1970, with the III Perfection in it ?
If you do could you please scan and post the Pages for it.
I built one in the 1980's, It flew well and was a sort of a cross between a Kaos and a Quick fly III.
I have the Plan but onot the Mag and RCM sends only the Text with a plan [&o]
Thanks in advance
Johnkpap
Thanks in advance
Johnkpap
Thanks to Ray I have what I need
The plans that arrived from RCM are of a very high quality ....But the only send the Text from the article [&o], I have orded from MAN as well and you get it all the article
A picture is worth a 1000 words,
Thanks Everyone
Thanks Everyone
If I recall correctly, the article had only pictures of completed models. The plans give enough details to build the model. Very rarely did any of the construction articles include any kind of step-by-step pictures to go with the text. Most of the time, even the text said something like, "Assemble the ribs to the spars in the normal manner, and then add the leading and trailing edges. Carve and sand to the shape shown." ....and so on. That's enough for most plans builders, since the plans show how they all go together...or at least they should!
Hi Bax
Yes with the text and plan there is Enough info to build the plane.
The extra Photos Show the following:
The colours of the completed painted models, I like my models to look the right Vintage
How the tank hatch was setup :- the plan is not 100% clear !!
Servo Placement was not showen on this plan
I find this info very usefull
With other plans I have bought from RCM there was a complete photo Sequence for building the model in the Article
the "Text only" was not helpfull .....I have the Magazines for these plans so I did not have a problem building from them.
Johnkpap
Johnkpap
