Difference in products
MN
Can anyone define the difference in COVERITEs Balsarite "FILM" and "FABRIC" products? Just seems that they should be very close to the same formula without any real difference than price. Some suppliers advertise Film product at $11.99 and Fabric at $14.99.
Thanks for your insight.
Darryl
Darryl
Jim; Is Ironex available ? I haven't seen it in awhile.
As stated, the Fabric Formula is a higher viscosity. The last two cans that I purchased, jelled in the cans and I couldn't thin them down.
I have used the Film Formula on Solartex, though, and it worked well.
These days, I've been using Acqua Net hair spray, instead of Balsarite.
I too tried lacquer thinner, acetone, MEK, reducer for enamel auto paint. It would thin it, but it had a milky, sort of look. It also was settled to the bottom and was solid rubber. Not sure what could be used to thin it. Being I am in Kalifornia, I am not able to get either so I am left with cheap hair spray.
The two thing it was great for was fuel proofing and zero dust. Help covering stick to plywood like it was foam.
Buzz.
Buzz.
