Gasser to electric conversion chart?
If this is the wrong section, please let me know and I'll delete and move.
I have picked up the plans for a 1/6 scale Cessna Skymaster. It recommends in the plans to use a Saito 300 twin or equivalent for power.
After reading a lot on the twins, I think I'm more interested in going brushless. I cannot seem to find a comparison chart between a 50cc twin gasser and a comparable brushless motor.
I will need to double check, but I believe it said the prop was going to be a 20x10 or 22x10 front and rear. I would love to go 3 blade and make the plane into a Riley Super Rocket 337, but finding push and pull 3 blade 20 or 22 inch props is a challenge.
Anyway, anyone know what brushless motor and ESC to drive 2 of them would fit my bill here?
Thank you all in advance.
David, what engines would you recommend then? The plans say to use a Saitco 300 Twin in the front and a Saitco 130 Twin in the rear.
So what would be a modern equivalent (doesn't have to be a twin, just the same power output and RPM capabilities)?
Mickey_D (03-03-2021)
Thank you Steve. I had no idea that was how easy the search terms were LOL In 30 seconds I found 9 motors that will fit my bill exactly.
Thank you for the info Dave. If I decide to stick with gas power, I will make good use of your info. But being a Navy trained electronics technician, brushless is much more comfortable to me.
