Go Back  RCU Forums > Radios, Batteries, Clubhouse and more > Control Lines
Using an r/c engine with locked open carb >
Control Lines For all you fly-by-wire fanatics!
Old 09-13-2014 | 11:43 AM
Default Using an r/c engine with locked open carb
Hi all!
Does the setting of the low speed needle have any effect?
Annette
Old 09-13-2014 | 12:03 PM
My Feedback: (15)
No.
Old 09-13-2014 | 03:50 PM
downunder's Avatar
It could do if the low speed needle is wound much too far in where it can be inside the spray bar hole and that would show up by not being able to richen the high speed needle.
Old 09-13-2014 | 04:36 PM
What about the idle mixture screw on a single needle carb?
Annette
Old 09-13-2014 | 05:08 PM
My Feedback: (20)
the air bleed on a single needle carb will have no effect.
Old 09-16-2014 | 07:57 AM
aspeed's Avatar
The air bleed is blocked off, so it would not affect anything as was said. I make inserts for my rc motors. You would need a lathe or a friend with one. I don't like to bend the rc ones, as they are sticking out more than a control line one, A remote needle is out of the way too if you land/crash upside down or whatever. Hmm that happened Sunday on the white plane. I am glad I shortened the needle valve from when I took that picture.
Name:	Fora and Axial 004.jpg
ID:	2032483   Click image for larger version
Name:	ap .15 cl.jpg
