Control Lines For all you fly-by-wire fanatics!
Line question
Old 09-23-2021 | 02:05 PM
Default Line question
Hi all,
I haven't flown U-control in about 45 years. Use to fly Fox 35 size craft... etc...Loved it, but have flown RC that entire time since then. I'm wanting to get back into control line and have been trying to do some research first. What I can't find for some reason is any information on the lines to use for different size planes and engine combinations. Is there some source for that I might find? Thanks in advance for any help..
Old 09-23-2021 | 02:19 PM
My Feedback: (20)
Check out the C/L aerobatics (stunt) rules on the AMA web site. IIRC line size are spelled out for various model weights and engine sizes. For .35 or .40 powered models 0.015" works well.
Chuck
Old 09-23-2021 | 02:32 PM
Thank you...I'll check that out!
Old 03-08-2022 | 07:27 PM
You can also check the Brodak website.
They have the table for the recommended line size based on your engine size.
Old 10-23-2023 | 10:54 AM
Been reading this post on the right size stainless lines to use. Compared to your engine and aircraft weight. One Item that was not mentioned and is very important are your line connectors that attach to your handle and attach to the aircraft lead outs. Two types are offered the center slide and the scissor. Many flyers prefer the scissor connector. I am not new to U Control and experience the loss of an aircraft due to the center slide connector. When I started U Control in the early 60s it was I think.the only line connector that was available and it came in 3 sizes. They would get weak from connecting and reconnecting your lines. And usually doom to failure. Heat shrink was developed and That has solved alot of issues. I use it and keep my handle connected to my lines. Using heat shrink. I use the scissor clips on my aircraft lead outs. And apply heat shrink using a lighter. Just a small piece in the middle of the scissor clip. AJ
