Go Back  RCU Forums > Radios, Batteries, Clubhouse and more > Control Lines
 Need Help Identifying a Kit >
Control Lines For all you fly-by-wire fanatics!
Old 02-02-2005 | 07:28 PM
Default Need Help Identifying a Kit
I know this is a long shot, but I am wondering if any one can help me identify a control line model I had. I'm not sure who the manufacturer was, but I think it was Dumas. I think it was available in the late 70's, early 80's. The main things I remember about it, are the wing ribs. Instead of being your typical ribs, they were two pieces. (see attached pic) I also remember that it had tricycle gear on it. I know this is not much to go off, but if anyone recognizes a kit with ribs like that, it would give me a better avenue to look.
Old 02-02-2005 | 09:15 PM
My Feedback: (15)
Default RE: Need Help Identifying a Kit
Night flyer,
There are probably other sights out there with more info. But I think you have a model of a Crusader that was kitted by Dumas in the early 70s. I had one and used it in sport flying and with a third line for profile carrier. It did OK in carrier but I used a scratch built Bi-Plane that was easier to land and flew slow speed much better.
Here is some info:
Dumas Crusader
This model was kitted by the US company Dumas, probably in the 70s. It has not been manufactured for some time, although unbuilt/boxed kits occasionally come to light on the secondhand collectors market. It conforms to BCD rules completely and can be built exactly as per plan. Although the anhedral wing uses a rather unusual construction (known as the 'Detroiter' method), the model is nevertheless robust and performs very well. As the tailplane is all-moving, it is very powerful and must not have too much movement: say about 200 either way. If the model proves to be very sensitive to control inputs, reduce this movement even further. Plan
from this sight: http://www.cheffers.co.uk/bcdxstng.html
Tight lines,
Tom Perry
Old 02-02-2005 | 09:27 PM
fox4evr's Avatar
I agree with Tom. I just went out and looked at my Dumas Crusader kit and is appears to be the one. Let me know if you need more info to identify.
Lee TGD
Old 02-02-2005 | 10:25 PM
Wow, thanks for the info. It is much appreciated. Would it be possible to get a picture of the box, and art? The website did not show a picture of the model I just got a box with a red X through it.
Thanks again
Pat
Old 02-02-2005 | 10:38 PM
fox4evr's Avatar
Give me a bit of time to do this. Let me know what all you need to see.
Lee TGD
Old 02-02-2005 | 11:25 PM
fox4evr's Avatar
Pat, Heres a few shots
ID:	224299   Click image for larger version
ID:	224300   Click image for larger version
ID:	224301   Click image for larger version
Old 02-03-2005 | 01:50 AM
Yep, that's it! Thank you for your help. From what I remember, and judging by the pictures, it does not look like they had full-sized drawings that could be built off of. At least I know what to look for on eBay.
Thanks again,
Pat
Old 02-05-2005 | 11:05 PM
I believe Dumas also kitted a Corsair with similar construction. I have a crusader with ST 35 RC engine that I would part with if there is any interest. Its a little used but does fly well and the engine is a screamer.May even have a set of plans if I can find them.
[>:] KEEP YOUR LINES TIGHT
Old 02-07-2005 | 01:34 PM
Thanks for the offer, but I would prefer to build it if at all possible. Do the plans show full-size views of the parts?
Old 02-07-2005 | 02:48 PM
The plans are reduced in size and do not show the ribs. It could be built from the plans if they were enlarged.
I haven't located the ones I had. Haven't looked either but I will.
Old 02-07-2005 | 11:14 PM
fox4evr's Avatar
Pat if you really want to build one, I will part with mine. I decided not to build it some time ago and forgot about having it until I saw your post.
Lee TGD
Old 02-08-2005 | 02:15 PM
Why did you decide not to build it? How much would you want for it?
Pat
Old 02-08-2005 | 07:59 PM
fox4evr's Avatar
Pat, I have too many projects going right now. For a while I wanted to build a carrier ship, but its not doing alot in my area, so decided to not build it. Keeping a kit thinking it is, or may become a collectible is not for me. If they ain't going to fly, I don't want em. I will take 60.00 for it shipped to your location.
Lee TGD
Old 02-08-2005 | 09:57 PM
Hey Nightflyer-- I found the plans and if you want them send me a PM As I said they need to be enlarged.
Das
Old 02-09-2005 | 03:34 PM
Lee, THat sounds great. My hobby funds are a little short right now, but if you're not in a hurry I can PM you when Im ready.
Old 02-09-2005 | 07:45 PM
fox4evr's Avatar
Pat, Check your PM. Lee TGD
Old 02-10-2005 | 03:32 PM
I checked my in-box, but there wasn't anything there.
Pat
Old 02-10-2005 | 11:19 PM
fox4evr's Avatar
Pat, It must have went into cyberland. I think I said no hurry, its been setting a while anyway. If you decide you don't want it let me know asap. Someone else is interested in it, but you have first dibs for a while.
Thanks Lee TGD
Old 02-11-2012 | 04:19 AM
Hi all
I know this an older thread BUT need HELP please
I have just got back into C?L have a PT 19 ready to fly go's well.
RE Dumas Crusader
need measurements of Main wing cord and tip cord,leading edge to back of prop.trailing edge to leading edge of stab.,
Stab main cord plus wing tip as well as its span one side.
Many THANX to you all
CrocEnd
