Go Back  RCU Forums > Radios, Batteries, Clubhouse and more > Control Lines
 Electric Cox PT-19 Conversion >
Control Lines For all you fly-by-wire fanatics!
Old 05-03-2007 | 07:15 PM
skaliwag's Avatar
Default Electric Cox PT-19 Conversion
Would it be a feasable project to electrify an old Cox PT-19 to say Speed 400 power?
Old 05-04-2007 | 12:30 AM
build light's Avatar
Default RE: Electric Cox PT-19 Conversion
Conversions of older planes is a common occurance these days and times and with the availability of half A engines (or at least the better ones) on a decline, e-power is becoming even more attractive as a power source than ever before. If that is possible.
While the old Cox PT-19 was one of the better plastic offerings as to flyability, its performance was never stellar. True, it was the plane many a newbie cut his teeth on when it came to powered flight and was very popular for a long time.
I say it could be done but I think the best way to go would be a brushless motor for better efficiancy. The standard 400 brushed can motor is pretty heavy and can draw some high amps.
Also if you want to do more than just taxi, I think you would have to go with LiPo batteries. Not sure how heavy a Nicad or NiHm pack would weigh to deliver the amps needed.
Robert
Old 05-04-2007 | 12:57 AM
Hmmm. some quick looking around I came up with this:
http://cgi.ebay.com/2712-12-Outrunne...QQcmdZViewItem
Weighs one ounce and will put out up to 18 ounces of thrust. Far more thrust than needed but you would have to use a large prop to do so. You can use a 7.0 6.0 prop and get less thrus but probably still more than enough to get her off the ground. Only two dollars shipping from this dealer!
Robert
Old 05-04-2007 | 01:42 PM
Sport_Pilot's Avatar
I suspect those old Cox P-19's would fly well on an .07 and longer lines. An outrunner would be an opportunity to do that, use 1/2 wires instead of string, an outrunner, and clip the batteries to your belt to keep it light. It would be intresting.
